SMath new file loading mode
SMath new file loading mode - New page or new SMath instance for a new application - 消息
#1 已发布: 2024/9/9 17:26:53
ioan92
ioan92
181个赞,共124个帖子。
When I have already loaded an application in SMath and I want to load another application, the last one is always loaded as a new page and not as a new instance of SMath.
Sometimes (only), I want that the new application to be loaded in a new instance of SMath instead of a new page. How could I handle this option.
The reason for my demand is based on the intention of being able to run two or more applications on different screens of the same computer.
Thank you for your attention,
Ioan
#2 已发布: 2024/9/9 19:09:13
StvMath
StvMath
44个赞和1个踩,共76个帖子。
Just start another instance of SMath first, then load the other application in that.
ioan92 2024/9/9 19:28:00
#3 已发布: 2024/9/9 21:45:47
ioan92
ioan92
181个赞,共124个帖子。
Thanks,
It's perfect !
#4 已发布: 2024/9/10 09:48:42
oscar mauricio
oscar mauricio
1个赞,共10个帖子。
I normally don't start two instances of the application because when closing one of the instances an error is generated in the images inserted with the ImageRegion plugin of the instance that remains open.
I hope you can fix this.
#5 已发布: 2024/9/10 14:54:33
1,443个赞,共2,936个帖子。
I've found where is the issue, I can fix it.
ioan92 2024/9/10 17:43:00
#6 已发布: 2024/9/10 18:48:04
1,443个赞,共2,936个帖子。
Fixed. Seems that the Release manager doesn't work currently, so the plugin can't be updated, but the code is uploaded in the SVN.
The temporary folder that contains the images generated on the fly by the plugin now has a sub-folder for each instance of the program, therefore the issue shouldn't arise anymore (BTW probably it was already reported before).
2位用户喜欢此帖子
oscar mauricio 2024/9/10 19:32:00, ioan92 2024/9/10 20:37:00
#7 已发布: 2025/1/11 02:43:26
1,443个赞,共2,936个帖子。
Plugin updated
3位用户喜欢此帖子
Andrey Ivashov 2025/1/11 04:26:00, sergio 2025/1/11 16:19:00, Alvaro 2025/1/12 15:48:00
