Signals and Systems
Signals and Systems - Example of use of SMath for signals and systems analysis - 消息
#41 已发布: 2018/9/24 00:11:12
983个赞,共6,866个帖子。
Hi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expressed in F(s) form.
That one was well covered, two last remarks:
1. That Smath does not trig example [1], rather in terms of exp(,)
OK, unfamiliar ... but much faster as it involves only one numerical approximation.
Whatever: it's the Maple business, from which Smath depends upon.
2. last visit [red/cyan[ is sometimes of importance as demonstrated.
InvLaplace2 Otherwise.sm (49.53 KiB)已下载 1378 次。
#42 已发布: 2018/9/24 10:21:12
983个赞,共6,866个帖子。
... when you deal with Laplace stuff, open your school book,
that will help setup Laplace Algebra appropriately, like this:
#43 已发布: 2019/3/20 07:48:00
1,139个赞,共1,805个帖子。
Hi. Improved version, works faster. Coefficients for the inversion are precalculated outside the inverter caller and avoiding vectorization for more compatibility of the inverter.
InvLaplace3.sm (98.32 KiB)已下载 1433 次。
#44 已发布: 2019/3/20 14:01:50
983个赞,共6,866个帖子。
Thanks Alvaro,
Any real use for this old style inverser,
vs Maple export c/w parameters that works much faster.
Saludos ... Jean
Laplace Maple Parametric Export.sm (15.2 KiB)已下载 1384 次。
