Signals and Systems - Example of use of SMath for signals and systems analysis - 消息
However I've edited the link, now it downloads the file, whatever is your favorite browser.
Thanks Davide!!
The post shows a trasfer function solved for the poles and zeros... It looks like you have to know how many poles and zeros to solve for before getting going. That would require putting the transfer function in standard form I'm somewhat sure.
https://electronics.stackexchange.com/questions/243435/bode-plot-of-transfer-function?rq=1
WroteI'm still trying to get the hand of this software. I'm an e.e. undergraduate and would like to be able to perform the something like the mathcad at the end of this post. I did try to input a similar syntax but I'm too much of a noob to work it. Can anyone shed some light on this for me?
All documents attached are in Smath 6179, should work same imore recent version(s).
The Smath/Maple companions of this year [2018] work a bit different than Mathcad 11 [2003].
At the end, all attached documents work for me Smath 6179 same as my former Mathcad 11.
Inst_PID [ODE].sm (24.75 KiB)已下载 1108 次。
Inst_PID Discrete State Systems.sm (25.51 KiB)已下载 1343 次。
Inst_PID DynSys.sm (14.9 KiB)已下载 1258 次。
Inst_PID [PI, PID].sm (71.51 KiB)已下载 1126 次。
Inst_PID [P, PD].sm (106.94 KiB)已下载 1051 次。
Inst_PID Feedback Attenuator.sm (43.76 KiB)已下载 1285 次。
Inst_PID [MCD Model].sm (177.96 KiB)已下载 1121 次。
Inst_TurboGen Smath.sm (106.19 KiB)已下载 1313 次。
ODE_Laplace Read First.sm (27.41 KiB)已下载 1316 次。
Inst_TurboGen Signum.sm (91.08 KiB)已下载 1353 次。
Inst_PID Discrete Schema.sm (166.36 KiB)已下载 1348 次。
ODE_Laplace 1rst [Type 1].sm (24.7 KiB)已下载 1120 次。
Inst_XFR 2nd [XFR nth].sm (34.08 KiB)已下载 1128 次。
ODE_Laplace 1rst [Type 2].sm (22.5 KiB)已下载 1199 次。
Inst_PID DynSys_v01 (1).sm (235.59 KiB)已下载 1306 次。
ODE_Laplace 2nd [Type 3].sm (33.42 KiB)已下载 1134 次。
ODE Laplace Kinetic Reaction.sm (93.13 KiB)已下载 1311 次。
Here's an example of how one might attack it.
Page1.sm (44.98 KiB)已下载 1534 次。
Bravo! Alyles, simple and beautiful!!
WroteJean,
What why the invlaplace I get a dot?
Basile, mon ami, you need a new pair of glasses !
Just code as the snippet, it will gladly work for Basile.
Until I get my new pair, I see that a dot appears after the F(s) when I type a comma.
Any diagnosis?
Inverse Laplace-2.sm (4.25 KiB)已下载 1288 次。
Basile
WroteJean,
Any diagnosis?
Check from "Options" if you can fix .
WroteJean,
Can you be more specific?
Basile
From the menu tool bar up top work sheet:
Tools => Options => Interface => Arguments separator [period, coma, semicolon]
People have done some amazing things with it that I can't even begin to follow but I haven't been as successful. Perhaps as I become more competent I might be more successful but for now I think I will unfortunately have to hang up my hat gentlemen... I bid you a respectful adieu for the time being kind Sirs...
未找到文件。未找到文件。
magnetism.zip (5.26 MiB)已下载 497 次。
WrotePerhaps as I become more competent I might be more successfu
I have doctored few things in these two documents.
hw 2.6.sm (133.49 KiB)已下载 1282 次。
open loop gain from closed loop gain 2.sm (48.32 KiB)已下载 1276 次。
WroteHi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expresed in F(s) form.
enjoy
Oscar Campo
Hi. Enjoyed & Improved. Six years later.
InvLaplace2.sm (93.88 KiB)已下载 1311 次。
WroteEnjoyed
Thanks Alvaro for your dedication,
Does syntax error 6179, but does not to where it complains.
Don't worry, OK like this.
The 2nd example is lot more involved, correct [sanity MCD].
InvLaplace2 Otherwise.sm (27.68 KiB)已下载 1337 次。
