Inline division
Inline division - 消息
#1 已发布: 2021/12/15 23:52:35
Chito
Chito
1个赞,共6个帖子。
Is there any way to present division on the same line and not as a fraction? For example in Mathcad:
#2 已发布: 2021/12/16 08:51:57
983个赞,共6,866个帖子。
Is there any way to present division on the same line and not as a fraction ?
Maths Infix DIVIDE.sm (4.18 KiB)已下载 1281 次。
sergio 2021/12/16 09:19:00
#3 已发布: 2021/12/16 10:48:27
983个赞,共6,866个帖子。
#4 已发布: 2021/12/16 11:12:28
1,443个赞,共2,936个帖子。
If you don't need strictly a division symbol, you can use a multiplication
#5 已发布: 2022/6/17 15:33:17
⚜ Kenny Lemens, P.E. ᵂᴵ
85个赞,共181个帖子。
Greetings!
...division on the same line...
It is possible to combine Davide's and Jean's solutions, but you need to pull off a few tricks:
   1) Create a custom function with (1) parameter
   2) Use the special inline division character 「÷」
   3) Declare your custom function as a 'unit' (this suppress the multiplication operation from displaying)
To create the custom function with the inline division character, copy and paste the following into your SMath Worksheet:
'÷(_denom):1/_denom
To utilize it, type in your numerator and multiply it by the custom function, where you pass the denominator into the function as the parameter.
EXAMPLE: solving for 6/2; copy and paste the following (NOTE: since I am declaring the custom function as a unit; you must include ' when calling the custom function):
6*'÷(2)=#@#
-Kenny Lemens, P.E.
3位用户喜欢此帖子
sergio 2022/6/17 17:33:00, Chito 2022/6/20 03:27:00, Oscar Campo 2022/6/21 08:24:00
#6 已发布: 2022/6/24 17:10:31
85个赞,共181个帖子。
Greetings,
If you just need the statement to be on the same line and you want to avoid the use of exponents and custom functions, there is a native solution:
Use the function str2num(▮) and type your statement as a string:
You do have the ability to reference variables, but the use of whitespace (tab, space, newline, etc.) will corrupt the string and str2num(▮) will throw an error.
Thus this statement will work:
     str2num("(2+22)/4")=6
But this statement will throw a 'not defined' error:
     str2num("(2 + 22) / 4")=▮
Its a good day to be alive;
-Kenny Lemens, P.E.
#7 已发布: 2022/6/24 19:12:53
600个赞,共1,381个帖子。
In addition to Kenny you can remove white spaces.
Furthermore, you can define a nameless function with Ctrl+Shift+K.
It won't show a function before it, though it is a function.
By that your statement shall look as a "normal" calculation.
str2num.sm (2.62 KiB)已下载 1295 次。
#8 已发布: 2022/6/24 21:55:13
983个赞,共6,866个帖子。
Answer is NO, Smath does not have native ÷ operator
More productive from infix algo style utilities,
for infinite in-situ command line.
infix Divide.sm (3.5 KiB)已下载 1319 次。
#9 已发布: 2022/6/24 23:12:52
600个赞,共1,381个帖子。
Answer is YES, there are multiple ways demonstrated above. Choose what suits you most.
#10 已发布: 2022/6/25 14:43:46
983个赞,共6,866个帖子。
