Problem with l/min unit
Problem with l/min unit - 消息
#1 已发布: 2020/11/11 15:14:03
EngMath
EngMath
0个赞,共51个帖子。
I have a problem with units again. Can you help me ? Here's my input (I've also attached the .sm file):
D = 80 mm
d = 45 mm
f = 500 mm
t = 9 s
S = (π*(D^2-d^2))/4
Q = (S*f)/t
Result of the last formula is given in m^3/s but I would like to convert it to l/min (liters per minute). I click on the right placeholder and type: 'l/'min but the output I get is wrong:
What can I do to fix this ?
Liters per minute.sm (4.82 KiB)已下载 1525 次。
#2 已发布: 2020/11/11 15:35:13
127个赞,共342个帖子。
Liters "L" and not "l"
2位用户喜欢此帖子
Davide Carpi 2020/11/12 10:10:00, EngMath 2021/5/30 09:05:00
#3 已发布: 2020/11/11 16:31:19
EngMath
EngMath
0个赞,共51个帖子。
It works now, thank you very much.
