[X-Y Plot] Smath Page Freezing
[X-Y Plot] Smath Page Freezing - Can't scroll to end of page - 消息
#1 已发布: 2017/2/2 11:18:47
Ryan Freund
Ryan Freund
20个赞,共339个帖子。
See attached SMath calc. There are a pair of graphs at the bottom but I can't scroll to see them. The SMath page freezes.
Any thoughts?
Masonry - STR - Out-Of-Plane - Wall - V1.sm (198.25 KiB)已下载 1368 次。
Thanks,
#2 已发布: 2017/2/2 13:11:07
Arie
Arie
94个赞,共285个帖子。
Fixed. In your definition of Pu_Mu right above you had M.u instead of M.U. Not sure why it cause a crash. But now it runs.
Masonry - STR - Out-Of-Plane - Wall - V1.sm (198.27 KiB)已下载 1385 次。
FYI, the way I fixed this was to disable auto calculation. Then I scrolled down and disabled evaluation of each graph. I enabled the graphs one at a time and manually recalculated each time. The left one caused the crash. When I only enabled the right graph, it produced the error showing M.u was undefined. Then I could find the bad definition from there.
2位用户喜欢此帖子
Ryan Freund 2017/2/2 21:06:00, Davide Carpi 2017/2/3 04:33:00
#3 已发布: 2017/2/2 23:45:11
983个赞,共6,866个帖子。
Here, it does not crash but the work sheet is red from top to bottom.
