1页(5条)
How to write a over dot & double subscript levels? - 消息
i have to questions at the moment:
-is it possible to write a overdot like for the volumetric flow rate?
-how could i write double subscripts?
e.g.:
Many thanks in advance!
e.g.:
Hello Topaz,
I have no answer to your first question - I don't know.
Maybe another user has a solution for that.
To your second question:
as far as I know (and use), you can only write one (1) subscript, but you can than add an index number with the "[" key.
in fact you define a vector.
see the attached file未找到文件。未找到文件。
kind regards,
csb
kind regards,
csb
In maths works ang Engineering works, subscripts are confusing.
To me: completely useless, never use. Occasionaly, as short
description is usefull to evidence the RHS construction.
Further, Smath is very limited in the ASCII 'Alt+0key'. Probably
because of the so many languages it was designed to accomodate.
NONE of my Smath Engineering work sheet contains subscript.
Inst_Colebrook Pipe Data.sm (60.85 KiB)已下载 1284 次。
Inst_Orifice Plate.sm (430.13 KiB)已下载 1322 次。
1页(5条)
