SMath论坛 SMath Studio Questions Questions of solve function 1页(2条) Questions of solve function - 消息 转到最后一个帖子 #1 已发布: 2024/8/30 08:11:47 soomoon 1个赞,共42个帖子。 组: User he first formula calculated well.The second formula did not calculate.The result is "The stack is empty."What is the problem?未找到文件。未找到文件。 #2 已发布: 2024/8/30 09:18:59 overlord 600个赞,共1,381个帖子。 组: Moderator Either clear R or use a different variable name, R.1 for example.Because you defined R at upper calculation, it confuses solvers.Regards 1页(2条) 有新帖 无新帖
