my problem is that if I select whole text line and try to copy it and paste to notepad (or back to the same SMath sheet) I get only part of selected text.
Steps to reproduce:
1. open new worksheet
2. input this text:
a el(Re.a,1,1):{nthroot(Re/b,3)+sqrt(3.6)}/sin(3)/{4^{2-o}}}
- as there is a space as second char, this is treated as text region (alternatively one can use
Insert->Text region and then insert this text or similar).
Then double click on inserted text. All text is selected. Then copy (^C) and paste it (^V). Only part of text is copied. Attached sample file.
selection_copy_bug.sm (2.02 KiB) downloaded 989 time(s).
