Issue in SmathStudio with "Solve"
Issue in SmathStudio with "Solve" - For a long time I can't solve the problem in this program, I can't find the roots - 消息
#1 已发布: 2020/3/11 11:40:16
Joki720
Joki720
0个赞,共12个帖子。
Project
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode.sm (1.44 MiB)已下载 1301 次。
Please help, I know you can
#2 已发布: 2020/3/11 15:01:10
983个赞,共6,866个帖子。
The first error message is in Function_Prop
It says "must be a real number" ?
#3 已发布: 2020/3/11 15:04:25
983个赞,共6,866个帖子。
... collapsed area are locked ! password.
#4 已发布: 2020/3/11 15:27:21
Joki720
Joki720
0个赞,共12个帖子。
Password 2153
But it`s not effect to my Issue
#5 已发布: 2020/3/11 15:32:11
Joki720
Joki720
0个赞,共12个帖子。
It`s file without first error, you can use it.
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode.sm (1.44 MiB)已下载 1308 次。
#6 已发布: 2020/3/11 19:23:58
983个赞,共6,866个帖子。
... does not either SS 6179.
You may replace Function_prop(P,T,M) by the Spline Matrix
Collapsed in red ... try some suite from there.
Watch unit system [not my cup of tea !]
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode (1).sm (1.52 MiB)已下载 1269 次。
#7 已发布: 2020/3/11 22:22:58
983个赞,共6,866个帖子。
Still red top2bottom
As it looks, you are attempting to integrate kg/m³ over 'p'
for the given 293 °K ... done otherwise finite differences.
In your solve block, vary many things are constants that could
be simplified but so many are undefined.
What should this solve bloc should do wrt the integration ?
find an intersection wrt some 'P' or else ?
The meaning of the cumulative integration reads like this:
"for °K 293, accumulate the kg/m³ over the 'p' range'
In other words: the cumulative mass-flow kg/m³over 'p' range
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode (1).sm (1.53 MiB)已下载 1274 次。
#8 已发布: 2020/3/12 08:40:48
Joki720
Joki720
0个赞,共12个帖子。
I don't understand you. What should I do? Or, if You can, please correct it
This is the correct response to the variable that should be obtained in the Solve function
InkedRaschet propusknojj sposobnosti truboprovoda s drosselem na vykhode_LI.jpg
#9 已发布: 2020/3/12 12:26:51
983个赞,共6,866个帖子。
Function_prop(P,T,M) does not work.
Use the Spline Matrix in lieu
I understand nothing in there.
Hope Collabs read and have some ideas !
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode (20200312).sm (1.54 MiB)已下载 1301 次。
#10 已发布: 2020/3/12 19:56:35
Joki720
Joki720
0个赞,共12个帖子。
I don`t understand too. May be anyone have any idea?
#11 已发布: 2020/3/13 04:43:39
1,362个赞,共2,276个帖子。
I fixed Function_Prop using InterpBilinear() from the Statistical Tools plugin. Note that the definition without line operator behaves buggy, because you even won't get the usual storage preview when hovering over the definition. This is strange and indicates something really bad under the hood.
Yet fixing the function doesn't solve any of the problems downstream. But given the strange error messages and bugs I'd say build 7251 can't be used safely anyways.
BTW, instead the if-else cascades I'd recommend using the selection index as index of a vector of options.
2020-03-13 08_26_21-SMath Studio 0.99.7251 - [Raschet%20propusknojj%20sposobnosti%20truboprovoda%20s.png
Raschet%20propusknojj%20sposobnosti%20truboprovoda%20s%20drosselem%20na%20vykhode_Kr.sm (1.44 MiB)已下载 1393 次。
#12 已发布: 2020/3/14 16:19:30
Joki720
Joki720
0个赞,共12个帖子。
Perfect, may be you can solve "SOLVE" function in this program???
#13 已发布: 2020/3/14 21:26:36
983个赞,共6,866个帖子。
Perfect, may be you can solve "SOLVE" function in this program ???
1. Up to this point: NO ... μ.др is undefined
2. If μ.др has a value: plug it in this document.
3. Please, don't re-post your original, so I can do more
from this document.
4. Units don't match in this project.
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode (20200314).sm (1.52 MiB)已下载 1255 次。
#14 已发布: 2020/3/15 09:29:47
983个赞,共6,866个帖子。
... look closely at the point we are.
Define the base viscosity μ.др
The complex term is most puzzling ?
Raschet propusknojj [20200315].sm (1.52 MiB)已下载 1048 次。
#15 已发布: 2020/3/15 15:25:18
Joki720
Joki720
0个赞,共12个帖子。
Sorry. I understand you, I didn’t write it down. instead of μ.др . -> μ.тр
#16 已发布: 2020/3/16 21:51:00
983个赞,共6,866个帖子。
... now that we have the base viscosity, we can plot/tabulate "Bloc".
From there, given some value in "Bloc" we can solve for the pressure
that creates this value .
Cheers ... jean
Does it make you progress in your project ?
Raschet propusknojj [20200316].sm (1.55 MiB)已下载 1008 次。
#17 已发布: 2020/3/17 11:04:05
Joki720
Joki720
0个赞,共12个帖子。
Cheers ... jean
The answer does not match, it might be better if I attach a file from MathCad. I have to translate the program from MathCad to SmathStudio, but sometimes I get errors like this.
Raschet propusknojj sposobnosti truboprovoda s drosselem na vykhode.xmcd (487.33 KiB)已下载 1312 次。
Here is the answer, sorry, that in Russian
#18 已发布: 2020/3/17 14:48:43
983个赞,共6,866个帖子。
... then check if the "Bloc" you have constructed is OK.
Tabulate the Mathcad "Bloc" that you have translated Smath.
My working Mathcad is 11 not connected to Internet,
My XP Pro. has no AV . If the two MCD/Smath blocs don't
agree/tabulate same: then your translation is in doubt.
#19 已发布: 2020/3/20 12:11:57
983个赞,共6,866个帖子。
Your Smath ρ vs pressure [p] does not correspond to MCD.
I can't help more from so much not clear.
Check with Viacheslav, he is with MCD ... Maybe Radovan too.
Cheers, best ... Jean
