(SOLVED) HRESULT: 0x800700C1
(SOLVED) HRESULT: 0x800700C1 - mushoe - 消息
#1 已发布: 2013/10/8 19:11:01
Mushoe
Mushoe
0个赞,共3个帖子。
Please help! I am trying to do a simple natural log function and I keep getting the error " is not a valid Win32 application. (Exception from HRESULT: 0x800700C1)".
I am running v0.96 (build 4909) on Windows 7 x64.
#2 已发布: 2013/10/9 03:11:10
uham1867
uham1867
0个赞,共2个帖子。
hi mushoe
if you have installed one or more WIN 32 plugin delete it, then it should work
Greetings uham67
#3 已发布: 2013/10/9 05:19:11
1,362个赞,共2,276个帖子。
Do you use the unofficial portable distribution? If not, you might give it a try.
Edit: Link corrected
#4 已发布: 2013/10/9 05:41:53
127个赞,共342个帖子。
Hi Martin,
the link to the "unofficial portable version" does not work properly (Page not found)
Davide Carpi 2013/10/9 06:55:00
#5 已发布: 2013/10/9 07:58:48
kilele
kilele
134个赞,共397个帖子。
This is the correct link
#6 已发布: 2013/10/9 10:03:10
Mushoe
Mushoe
0个赞,共3个帖子。
I tried removing all plugins from my install, but that did not work. I then tried the portable version and it solved my issue!
Thank you so very much!
I had defined r0 above, I just forgot to move it down when I took the screen shot.
Mushoe
#7 已发布: 2013/10/9 10:16:36
1,443个赞,共2,936个帖子。
Good
BTW I suggest you to follow the hint made by ioan92, sometimes something goes wrong with the installed version, a clean install can solve issues (tried myself this summer with an annoying red cross of death moving the vertical scrollbar)
regards,
Davide
#8 已发布: 2013/11/27 13:19:21
Mushoe
Mushoe
0个赞,共3个帖子。
Just a follow up. I have been using the unofficial portable version for a while now and it has been working as expected with no strange errors. Thanks again to all for the help!
https://smath.com/wiki/(S(iymz0v3hvaquj12ic1kr4yfo))/Default.aspx?Page=SMath%20with%20Plugins
