1页(7条)
Smath changes the final unit arbitrarily not what I want - 消息
Hi All
having defined some parameters let's say with the unit of Mpa I noticed that the final results are given in Pa (Pascals) and I can not change it or I don't know how to change or preset to force Smath to give me the results in Mpa. Any ideas ?
It's not changing them "arbitrarily", it uses base SI units. There's no preset currently (except for currently unsupported direct-edit way to choose imperial units). But you may put cursor to the trailing placeholder in an expression and put the desired units there.
С уважением,
Михаил Каганский
Hi farzad. Check from minute 2"30.
https://smath.com/wiki/Units.ashx
引用Evaluating an expression that contain units, the output will be delivered with the default units (SI base units); to change the output unit, write your favorite unit in the right placeholder.
None of this works for me. I need to change 'Pa into 'kWh/'m^3 (energy density) but trying to insert my units into the trailing placeholder just produces a mess of other units. Sometimes the actual calculation gets messed up too!
Bill
Bill
WroteNone of this works for me. I need to change 'Pa into 'kWh/'m^3 (energy density) but trying to insert my units into the trailing placeholder just produces a mess of other units. Sometimes the actual calculation gets messed up too!
Bill
Hello Bill,
this is because kWh doesn't exists in the built-in units; you have to use 'kW*'hr/'m^3 or define your own unit somewhere in the worksheet (see the attachment)
kWh (cloud)
![2016-08-05 11_14_09-SMath Studio Desktop - [kWh.sm].png](/zh-Hans-CN/files/Download/cWNSp8/2016-08-05-11_14_09-SMath-Studio-Desktop---[kWh.sm].png)
Andrey Ivashov 2016/8/5 11:21:00
1页(7条)
