1页(5条)
Animated graphs -v0.90 versus v0.91 - 消息
I think that everybody knows the famous Ber7 animations here on the Forum
I tried the few recent ones
https://smath.com/wiki/GetFile.aspx?File=Cannabis.rar
https://smath.com/wiki/GetFile.aspx?File=Graf1.rar
https://smath.com/wiki/GetFile.aspx?File=Graf2.rar
Unfortunately, they do not work the same as in v.0.90. Actually, the first one is not visible at all, and on the second two only the points are visible but not the curves. Is there any problem about it?
Hello.
I mentioned about it earlier in that comment: http://en.smath.info/forum/default.aspx?g=posts&m=5921#post5921
Unfortunately all animations done with 0.90 must be updated like shown in the image below (all global variables changed within function must be specified as function arguments to fix graphs):
Unfortunately the error introduced in 0.90 was too bad
Best regards, Andrey Ivashov.
No harm done Andrey
Do not worry about it. It is another example about how is this suppose to work and just to clarify the things once more.
All animation files updated to version 0.91
3位用户喜欢此帖子
WroteAll animation files updated to version 0.91
Thank you very much!
Regards.
1页(5条)
