ScrollBarEx Region
ScrollBarEx Region - One more scrollbar control. - 消息
#1 已发布: 2014/5/2 10:35:17
1,558个赞,共1,868个帖子。
Scrollbar control based on Regions.Control class.
显示剧透
Password: test
Used as an example of the region without a place holder.
Links:
1. Custom Drawn Scrollbar (Thomas Duwe).
2位用户喜欢此帖子
Andrey Ivashov 2014/5/2 11:24:00, Davide Carpi 2014/5/2 11:38:00
#2 已发布: 2014/5/2 11:41:04
1,443个赞,共2,936个帖子。
Cool
the right-click shows me an unhandled exception
************** text of exception **************
System.NullReferenceException: object reference not set to an instance of an object.
   in SMath.Control.Worksheet.GetStaticContextMenuItems(RegionBase[] regions)
   in ..(List`1 )
   in ..‡(Object , EventArgs )
   in System.Windows.Forms.ContextMenu.OnPopup(EventArgs e)
   in System.Windows.Forms.ContextMenu.Show(Control control, Point pos, Int32 flags)
   in System.Windows.Forms.Control.WmContextMenu(Message& m, Control sourceControl)
   in System.Windows.Forms.Control.WndProc(Message& m)
   in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
#3 已发布: 2014/5/2 12:41:47
1,558个赞,共1,868个帖子。
I decided to use my own Control class for quick porting of such components. Yes, some artifacts remain. This component will be used in a script (text) editor.
Regions.Control is a draft version, it's not so easy to create full functional Control class.
Davide Carpi 2014/5/2 14:47:00
