Plane, sphere and cone
Plane, sphere and cone - 消息
#1 已发布: 2024/2/20 14:02:30
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
I want to solve three equations with three unknowns and display the solution on a 3D graph with two points - the roots of the equation.
Help please!
#2 已发布: 2024/2/20 20:01:51
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
Mathcad 15
#3 已发布: 2024/2/20 23:02:25
600个赞,共1,381个帖子。
Findroot() or roots() could solve three unknown systems.
About plotting, I simply wrote equations according to solving of z.
3Dplot_OchkovVF.sm (4.51 KiB)已下载 1598 次。
2位用户喜欢此帖子
Valery Ochkov 2024/2/20 23:05:00, Davide Carpi 2024/2/21 17:30:00
#4 已发布: 2024/2/21 06:54:08
1,362个赞,共2,276个帖子。
3Dplot_OchkovVF_Kr.sm (329.75 KiB)已下载 1671 次。
Davide Carpi 2024/2/21 17:29:00
#5 已发布: 2024/2/22 02:40:57
600个赞,共1,381个帖子。
Is there a way to use CreateMesh() for single line xyz equations?
x^2+y^2+z^2-2^2 creates a sphere in 3dplot, a finer mesh can look better.
But I don't know how to convert an equation to CreateMesh().
I am asking if it is doable of course, if they are two different thing it is ok.
A simple, short but inclusive tutorial would be beneficial.
#6 已发布: 2024/2/22 18:38:16
StvMath
StvMath
44个赞和1个踩,共76个帖子。
Like in the attached? (Though I confess it was a "suck it and see" approach as I don't fully understand the 3D graphing!)
TriangleSpherePlaneCreateMesh.sm (6.92 KiB)已下载 1661 次。
#7 已发布: 2024/2/22 23:36:19
600个赞,共1,381个帖子。
Not really, my question is different.
You can make any object with CreateMesh().
You can make sphere, plane, cone, cube, etc with mesh.
I ask for a method converting a xyz function to CreateMesh() matrix.
If there is any of course.
#8 已发布: 2024/2/29 11:56:27
1,139个赞,共1,805个帖子。
Hi Overlord. If you can isolate some of the x, y or z variables, you can use this. If not, Viacheslav develops a 3D implicit plot codes for mathcad, you can see that somewhere in the mathcad forum.
create_mesh_xy.sm (8.42 KiB)已下载 1641 次。
#9 已发布: 2024/2/29 16:46:48
1,558个赞,共1,868个帖子。
The dots on the graphs above are a sign of my code being used.
This is only possible for simple cases if the function is easily parameterizable.
