Copy and paste a picture
Copy and paste a picture - 消息
#1 已发布: 2011/11/29 17:43:55
abustillos
abustillos
1个赞,共4个帖子。
Hello! I would like to know how can I paste a picture from a word document or another Smathstudio file to a new Smath Studio sheet???
Thanks...
#2 已发布: 2011/11/29 20:00:48
Edward Ulle
Edward Ulle
21个赞,共182个帖子。
Try Windows Cut and Paste.
I embed sketches in my SMath files all the time. That works for me.
Ed
#3 已发布: 2011/12/5 14:22:14
abustillos
abustillos
1个赞,共4个帖子。
The copy and paste function doesn't work in my file.......do you have any idea what could be wrong?
Thanks..
Fridel Selitsky 2011/12/5 15:54:00
#4 已发布: 2011/12/5 15:33:59
kilele
kilele
134个赞,共397个帖子。
What's wrong? It works for me at least in 0.89 stable.
Try right click over a picture in msword and copy it to clipboard, right click again over your smath sheet and paste.
#5 已发布: 2011/12/5 17:24:43
Edward Ulle
Edward Ulle
21个赞,共182个帖子。
I discovered you can not copy a picture directly to SMath. By directly I mean you can't copy a jpeg or tiff file. You need to open it with something like Paint and then copy and paste to SMath. I was able to copy a photo from Paint and Word to SMath, no problem.
Ed
#6 已发布: 2011/12/13 05:51:46
benbig
benbig
0个赞,共3个帖子。
I can insert picture "from file". But the picture can not then be stretched/resized after insert.
#7 已发布: 2011/12/13 15:28:19
325个赞和1个踩,共2,052个帖子。
Unfortunately, It is not possible to stretch/resize the picture inside SMath at the moment.
#8 已发布: 2012/1/5 18:00:18
amit28it
amit28it
0个赞,共16个帖子。
Copy and paste to a picture is as usual as windows .But i am also recently knowing that Smath can' adjust images a/c to users view as told by omorr.So i will think that he will be knowing the way to handle this .
#9 已发布: 2012/1/5 18:08:21
...So i will think that he will be knowing the way to handle this .
You can not resize the picture inside SMath. Just try it and you will see that the picture region will be resized but the picture itself will not be adjusted. If you want to insert a picture into the SMath page, just resize it in some other picture managing software to the size you need.
I hope I understood your question and gave you the appropriate answer.
#10 已发布: 2012/2/3 18:02:47
Shiwani Thakur
Shiwani Thakur
0个赞,共7个帖子。
How can I insert the snapshot of SMath file in post? I did try copy and paste, but its not working. The option 'Insert image' asks for URL link.
Thanks & regards,
Shiwani.
#11 已发布: 2012/2/3 18:19:59
1,443个赞,共2,936个帖子。
hi,
there are 2 ways:
- using the Wiki, as explained here Notes on Using the Forum
- by uploading your image in a external free image hosting service (like tinypic.com or imm.io) or in a external general file hosting service (like mediafire.com)
then you can copy the uploaded image link in the "Insert Image" on the forum...
w3b5urf3r
