vectorize with function/procedure
vectorize with function/procedure - vectorize not working as I expect to do - 消息
#1 已发布: 2017/4/15 12:59:18
Martin_B
Martin_B
22个赞,共84个帖子。
Please have a look a the following example:
The first two results look good.
But why assigning the formula to a variable not work?
And the result test2 doesn't look right, does it?
vectorize.sm (11.66 KiB)已下载 1392 次。
Thanks for your help!
#2 已发布: 2017/4/15 19:12:32
983个赞,共6,866个帖子。
Result is same as if done by hand.
vectorize.sm (11.54 KiB)已下载 1430 次。
#3 已发布: 2017/4/16 06:46:10
Martin_B
Martin_B
22个赞,共84个帖子。
Probably I don't really understand how vectorize works.
If _I_ would do it by hand,
  • I take the first element of "f" and the first element of "phi" (the two vectors in the expression)
  • I calculate the result and put it as first element in a vector
  • I continue with the the second elements ...
  • I would obtain a two-element-vector
that's what I get by evaluating the expression
vectorize(f*K.agh(φ,5*'°,0*'°,0*'°)
I don't understand why it's a different result if this expression is assigned to a variable.
If the first factor within vectorize is a scalar, the error "Matrix must be square." is shown. But again only if the expression is assigned to a variable.
Everything works fine with functions without the line command. (But it's not possible to to do it without line in every case.)
vectorize2.sm (15.8 KiB)已下载 1358 次。
#4 已发布: 2017/4/16 09:42:18
325个赞和1个踩,共2,052个帖子。
The problem is in the function definition with or without line environment (as you already noted), and using the function call inside vectorize. See the picture please.
It might be a bit peculiar (maybe a bug) but one should be careful about it. It is advisable to assign the values to variables first and then to use vectorize (not to use function calls with vector arguments inside vectorize). Anyway, your gave an example where one can be easily confused.
Martin_B 2017/4/17 16:06:00
#5 已发布: 2017/4/16 19:57:44
983个赞,共6,866个帖子。
Nice comment Radovan,
The Mathcad vectorize operator is particular to Mathcad.
No fixed rule, just case by case. Same applies to Smath.
vectorize demo.sm (32.37 KiB)已下载 1420 次。
Radovan Omorjan 2017/4/17 04:16:00
#6 已发布: 2017/4/24 09:53:59
Martin_B
Martin_B
22个赞,共84个帖子。
Found another strange behavior (as I think):
Shouldn't vectorize handle 1-element vectors like any other with more elements?
#7 已发布: 2017/4/24 12:26:05
1,443个赞,共2,936个帖子。
It should. I think I can fix it, thank you (see BTS SS-2443)
As for the initial problem, I tend to consider it a bug/issue, simply because what you get when the function is on the left side of an evaluation is not what you get when the function is on the right side of an assignment.
#8 已发布: 2017/4/24 12:58:15
983个赞,共6,866个帖子。
Vectorize operator operates on the RHS of an equation !
Example [1] is oK
Example [2] would not support the RHS of different unit dimensions [m, km ...]
"type conversion not supported".
#9 已发布: 2017/4/24 13:23:12
Martin_B
Martin_B
22个赞,共84个帖子。
Example [1] is oK
OK.
Let's put the operator on the RHS and vary the units:
#10 已发布: 2017/4/25 11:24:53
983个赞,共6,866个帖子。
Not sure I understand your problem.
Visit "Samples" [2 months back or +]
several examples of vectorizing associated with functions.
Cheers, Jean
vectorize bolean.sm (21.28 KiB)已下载 1390 次。
#11 已发布: 2017/4/25 12:45:14
Martin_B
Martin_B
22个赞,共84个帖子。
I just mentioned, that vectorize cannot handle vectors with the length 1.
And I think it should.
Or the other way round: Why do you think, it is correct the way it works at current state.
And my previous post was a reply to your comment to show that RHS or not doesn't matter and that unit dimensions also don't affect "my" problem at all.
