ARRAY/MATRIX QUESTION
ARRAY/MATRIX QUESTION - LARGE VECTORS/MATRICES - 消息
#1 已发布: 2023/6/7 18:50:57
RegRetired
RegRetired
8个赞,共144个帖子。
Is there an easy way to scroll through a very large matrix?
Thx
Reg CurryLoveland, CO
#2 已发布: 2023/6/8 12:10:28
983个赞,共6,866个帖子。
Is there an easy way to scroll through a very large matrix ?
Very easy as suggested.
Page8 Scroll Matrix.sm (3.52 MiB)已下载 1514 次。
#3 已发布: 2023/6/8 14:46:17
983个赞,共6,866个帖子。
If you can't download attached documents,
can you attach your big matrix ?
Describe/explicit your demand.
#4 已发布: 2023/6/8 17:58:05
983个赞,共6,866个帖子。
Scroll matrix ... quick/quick/done
#5 已发布: 2023/6/8 18:23:01
1,139个赞,共1,805个帖子。
Thx
Hi. I guess that the effort less way is putting the matrix into a Table region, and using the 8 three dots that appear at borders and edges for navigating in the matrix.
#6 已发布: 2023/6/8 18:34:36
983个赞,共6,866个帖子。
Answer is YES matrix ... NO w/o matrix.
That means, attach your large *.sm matrix.
#7 已发布: 2023/6/8 20:03:03
RegRetired
RegRetired
8个赞,共144个帖子。
I like the idea of tables; however, as far as I can tell, it will not do continuous scrolling. Maybe I am missing something.
未找到文件。
Reg
Jean, I am having trouble understanding how to use your sm file.
#8 已发布: 2023/6/9 07:53:23
983个赞,共6,866个帖子。
Download this one, confirm you can open.
Simply a bit more descriptive, cross hair helper from Padding the region
Padding is what we use to zoom Fourier a gray or RGB image, up to zoom 2.
For larger zoom, I use IrfanView or WinGrab.
Cheers ... Jean. Take Care.
Image Matrix Scroll Region Copy.sm (3.88 MiB)已下载 1408 次。
#9 已发布: 2023/6/9 08:56:50
600个赞,共1,381个帖子。
You are not missing anything.
There is no continuous scroll for table region.
