Beta: SMath Studio 0.99.7200 (18 September 2019) - 消息
它提供了众多的计算功能和丰富的用户界面,并支持约40种语言。该应用程序还内置了数学参考手册。
应用程序可根据您的需求轻松扩展。内置的“扩展管理器”工具让您可以获取数百种官方及第三方资源,涵盖以下类型:使用示例、插件、基于 SMath Viewer 的应用程序、代码片段、界面翻译、交互式书籍、手册以及教程。
下载
SMathStudioDesktop.0_99_7200.Mono.tar.gz (1.39 MiB)已下载 2531 次。
SMathStudioDesktop.0_99_7200.Setup.msi (2.27 MiB)已下载 4910 次。
By same token, does it run correctly the Fission project ?
It failed previous SS 7109.
Project Fission.sm (166.12 KiB)已下载 1763 次。
it omits showing the description of the variable.
In the Tables, it does not respect the settings given in any previous version.
For now it is all that I have found, and I wonder, why in each new version, one thing is fixed and another is upset?
Thank you.
WroteFor now it is all that I have found, and I wonder, why in each new version, one thing is fixed and another is upset?
My suggestion is augment/enhance SS 6179.
1. Clean arithmetic palette from [1,2,3,4,5,6,7,8,9,0 ... +,-,*,/ =]
2. Replace Gamma(x) by Alvaro 15 D accuracy.
3. Add Carlos integrator algorithm.
4. Design a Clear(,) that evaporates previous use.
5. Maths in text region is baby classroom ...
Mathsoft demonstrated, only Jean used it few times.
6. Some Mathcad documents ORIGIN 0 can't be converted ORIGIN 1,
thus exclude Smath as well.
... few more
BTW Carlos: Fission is OK or red like 7109 ?
Additionally, Maple tools also failed.
WroteThanks Andrey for cuddling our so cherished Smath.
Thank you! Fixed here: https://en.smath.com/forum/yaf_postsm59417_Beta--SMath-Studio-0-99-7201--19-September-2019.aspx
WroteIt seems that this new version of Smath Studio has several problems, for example sometimes
WroteIn the Tables, it does not respect the settings given in any previous version.
I will check Table Region today.
Wroteand I wonder, why in each new version, one thing is fixed and another is upset?
It is because complexity of the program is very big and I have no testers except myself. I just can't test everything before every single release. That is why I introduced beta versions, so we can catch all problems before stable release.
WroteWroteThanks Andrey for cuddling our so cherished Smath.
Hello Andrey,
This problem was fixed in the recent version (7201). Thank you.
this problem triggered another one regarding the small numbers.
I am still quite puzzled with this. Especially when you are trying different optimizations???
Best Regards,
Best Regards,
This was fixed today. New version will be available in several hours.
WroteI will check Table Region today.
I've checked TableRegion and see that it uses
Hello Jean
Fision is Ok also in 7202
WroteWroteI will check Table Region today.
I've checked TableRegion and see that it usestag to store data which is restricted as SMath Studio uses this tag for its own purposes. I've implemented a workaround to the logic of opening files to allow TableRegion work with tag but I can't guarantee that this workaround will continue working in future releases. So, it is pretty important to switch plug-in to use another tag name for its purposes.
Hello Andrey
Thank you very much, now, the function Show description and Table, work very well in version 7202
