Estimating Fricton Factor accurately
Estimating Fricton Factor accurately - A very accurate equation for calculating the friction factor directly, without trial and error - 消息
#1 已发布: 2023/5/17 19:01:41
Javier Ochoa
Javier Ochoa
3个赞,共26个帖子。
Reading the article I could be able to calculate the friction factor for the Colebrook Equation and Reynolds number greater than 2500 for any ratio between the roughness and the diameter, due to the SMath Studio solvers with a set of 70 points simultaneously.
Then, I compared to other solutions found in two different articles and a table of the maximum absolute deviation and average deviation are presented at the end of the worksheet.
Hope it help,
Kind regards
friction_factor_Colebrook.sm (82.56 KiB)已下载 1630 次。
#2 已发布: 2023/5/17 20:54:32
983个赞,共6,866个帖子。
Hope it help,
Sorry ... not a bit ! We are CAS age [Computer Algebra System]
... of which Smath ranks top for Engineering applications.
Inst_Colebrook MOODY.sm (16.88 KiB)已下载 1630 次。
Inst_Colebrook Pipe Data.sm (75.07 KiB)已下载 1763 次。
Javier Ochoa 2023/5/18 09:34:00
#3 已发布: 2023/5/18 10:07:22
Javier Ochoa
Javier Ochoa
3个赞,共26个帖子。
Hi Jean,
Thank you for the worksheets, they will help me to think more like the way Smath Studio was thought to be (CAS).
#4 已发布: 2023/5/18 11:31:13
983个赞,共6,866个帖子。
Hi Jean,
Thank you for the worksheets.
They will help me to think more like the way Smath Studio was thought to be (CAS).
Augmented/refreshed ... Cheers ... Jean.
Inst_Colebrook MOODY.sm (31.64 KiB)已下载 1673 次。
