SMath units
SMath units - Wrong units - 消息
#1 已发布: 2023/11/24 05:13:51
Oichi
Oichi
4个赞,共35个帖子。
For a simple harmonic oscillator with mass "m" (kg) and spring constant "k" (N/m), the angular frequency of oscillation is sqrt(k/m).
If we used the SI units, the angular frequency unit should be (rad/s) but when I use units in SMath it gives the answer in Hz..
So, is there a way that I can correct the units for an answer? Thanks in advance
#2 已发布: 2023/11/24 17:38:44
Oscar Campo
Oscar Campo
135个赞,共309个帖子。
You can change units in this way...
Oscar
Oichi 2023/11/25 00:36:00
#3 已发布: 2023/11/25 00:13:01
983个赞,共6,866个帖子。
... Unit User Hz ... rad_s.sm (2.82 KiB)已下载 1418 次。
Oichi 2023/11/25 00:40:00
#4 已发布: 2023/11/25 00:40:02
Oichi
Oichi
4个赞,共35个帖子。
Thank you all ^^
Oscar Campo 2023/11/25 03:57:00
