Simple beam analysis, graph
Simple beam analysis, graph - Simple beam analysis, graph - 消息
#1 已发布: 2025/12/14 03:22:09
kimkim
kimkim
0个赞,共9个帖子。
Hi every one. I have some questions.
Q1) When performing symbolic calculations, I currently have to manually set the optimization to 'numeric' (or 'symbolic'/'none') for each region individually. Is there a way to change the default optimization setting to 'symbolic' or 'none' globally?
Q2) I have created a worksheet for the SFD and BMD of a simple beam, as shown in the image. I am trying to plot these diagrams using the XY Plot component.How can I restrict the x-axis range to display only the interval from 0 to 1?How can I mark the specific point of M_max on the graph?
Thank you for all.
12.SimpleBeam_01.sm (63.68 KiB)已下载 963 次。
#2 已发布: 2025/12/14 09:48:29
StvMath
StvMath
44个赞和1个踩,共76个帖子。
a. From Edit menu select All, then right-click on any blue region and select None from the optimisation section.
b. Double click on the graph and select the various options on the resulting menu - see attached.
12.SimpleBeam_01b.sm (86.53 KiB)已下载 992 次。
kimkim 2025/12/14 10:31:17
#3 已发布: 2025/12/14 10:35:04
kimkim
kimkim
0个赞,共9个帖子。
I'm so appreciative of you.
When I draw SDF, BMD,' roots' function is more efficient than 'Solve' function as you wrote!!
Thank you.
#4 已发布: 2025/12/17 22:39:59
1,362个赞,共2,276个帖子。
beam.sm (11.75 KiB)已下载 953 次。
3位用户喜欢此帖子
ioan92 2025/12/18 06:21:56, sergio 2025/12/18 11:04:41, kimkim 2025/12/18 20:44:40
