1页(7条)
Fit Methods Essentials - Fit Methods Essentials - 消息
Global fitting session [0 .. 14]
1. al_nleqsolve point select equalities
valid for noisy data via user piecewise linear.
2. Levenberg-Marquardt: generally valid [fails Frechet]
3. Cholesky matrix solver ... solves all, faster
model function(s) parameters, linfit components,
remarkable linfitCheby, polyorder, direct discrete data.
............................ rational fraction.
EMERITUS => Conjugate gradient Minimize(init,iter)
Genfit_0 Read First.sm (32.45 KiB)已下载 1366 次。
Genfit_2 L-M AUTOMATED PieceWise-Global Reflexive Copy.sm (69.25 KiB)已下载 1402 次。
Genfit_4 linfit HyperRobust [Ge Crystal] Copy.sm (82.26 KiB)已下载 1181 次。
Genfit_7 GenfitMatrix Copy Master ToolBox Copy.sm (62.69 KiB)已下载 1391 次。
Genfit_9 Chemist.sm (34.68 KiB)已下载 1324 次。
Genfit_5 LinfitCheby Order [HadCRU] Copy.sm (120.98 KiB)已下载 1195 次。
Genfit_8 Poly 000 Order System.sm (20.15 KiB)已下载 1329 次。
Genfit_3 L-M AUTOMATED PieceWise Carlos Original Copy.sm (130.72 KiB)已下载 1377 次。
Genfit_6 Rational Auto-init ITER [LongRange type_J] Copy.sm (123.72 KiB)已下载 1131 次。
Genfit_11 Pharmacokinetics LMSA ... [Carlos 2020].sm (50.36 KiB)已下载 1188 次。
Genfit_10 Frechet.sm (96.8 KiB)已下载 1362 次。
Genfit_13 NON-Linear.sm (37.25 KiB)已下载 1400 次。
Genfit_1 L-M AUTOMATED Carlos 20200115 [Exampless] Copy.sm (265.69 KiB)已下载 1152 次。
Genfit_14 AUTOMATED al_nleqsolve.sm (83.36 KiB)已下载 1371 次。
Genfit_12 Pharmacokinetics LM ... [Carlos 2018].sm (55.45 KiB)已下载 1151 次。
NDTM Amarasekera 2020/1/28 04:28:00
1 ... please: recycle Genfit_14
replace by high pro refreshed/augmented.
2. Add Genfit_15 [Thiele Procedure]
Genfit_15 Thiele Procedure [Carlos-Jean].sm (76.66 KiB)已下载 1182 次。
Genfit_14 AUTOMATED al_nleqsolve.sm (85.48 KiB)已下载 1406 次。
Hola Jean
This is my best setting for "Genfit_10 Frenchet" in SS-6179
with LM using 6 data, since an out of memory error occurs using all data.
SS-7251 solves it without any problem with all the data.
Genfit_10 Frenchet LMSA ..SS6179.sm (56 KiB)已下载 1328 次。
Genfit_10 Frenchet LMSA ..SS7251.sm (45.17 KiB)已下载 1335 次。
Hola Jean
Genfit_16 MERITAS resolved with LMSA in SS-6179 and SS-7251.
Genfit_16 MERITAS LMSA_SS6179.sm (53.02 KiB)已下载 1374 次。
Genfit_16 MERITAS LMSA_SS7251.sm (52.9 KiB)已下载 1383 次。
WroteHola Jean
This is my best setting for "Genfit_10 Frechet" in SS-6179
Thanks Carlos, got 9 points superb fit !
Next will check MERITAS ...
Genfit_10 Frenchet LMSA ..SS6179.sm (55.67 KiB)已下载 1362 次。
WroteHola Jean
Thanks Grand Doctor Carlos ...
So, my native SS 6179 suffers numerical issue
that SS 7251 cures in your SS 6179 ... Ah !
LMSA in native SS 6179 takes much higher TOL [typical 0.0001/0.00001]
F.B. Hildebrand wrote "fitting is an art ..."
Can't be more right !
1页(7条)
