XY Radial Grid
XY Radial Grid - XY Radial Grid - 消息
#1 已发布: 2016/11/6 10:21:09
983个赞,共6,866个帖子。
There is a bit more in the work sheet [Nsectors, inner radius].
More can be done... for instance: if the XY Lissajous would be
a closed isoline around a mountain, it would easy to adapt this
basic construction ... adjust the great circle, inner circle.
You can add/size the inner circles.
2D Radial Grid.sm (24.45 KiB)已下载 1522 次。
#2 已发布: 2016/11/6 11:48:44
983个赞,共6,866个帖子。
... ont his one: added noise on the inner circle.
2D Radial Grid.sm (42.48 KiB)已下载 1490 次。
#3 已发布: 2016/11/6 19:09:08
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
1.sm (8.6 KiB)已下载 1458 次。
#4 已发布: 2016/11/6 22:14:54
983个赞,共6,866个帖子。
Hello Ber7,
Thanks for that one. I guess that's how they size cauliflower heads !
