need help
need help - 消息
#1 已发布: 2026/5/9 08:35:16
Andreas Beldowski
Andreas Beldowski
0个赞,共17个帖子。
unfortunately, I can't find the error myself. Why VS(t) and VRG58(t) work well, but V1(t):=VS(t)-VRG58(t) not?
Regards Andreas
Auszug.pdf (114.69 KiB)已下载 421 次。
Auszug.sm (16.52 KiB)已下载 537 次。
#2 已发布: 2026/5/9 09:14:00
127个赞,共342个帖子。
It seems that the two quantities have different units of measurement.
#3 已发布: 2026/5/9 12:44:41
Andreas Beldowski
Andreas Beldowski
0个赞,共17个帖子。
Thanks Sergio,
wrong was VRG58(t):=Ig(t)*(1/ZLRG58+1/RRG58)
right is VRG58(t):=Ig(t)*(ZLRG58+RRG58)
Regards Andreas
#4 已发布: 2026/5/10 05:52:13
Andreas Beldowski
Andreas Beldowski
0个赞,共17个帖子。
and here’s another problem. Why does the differential of V1(t) work, but not that of V2(t)?
Both are sine functions; later, I’d like to try using square-wave functions as input as well.
For V1 and V2, I need the peak-to-peak amplitude and the phase difference between the two. I want to see if I can get better approximations for determining C1 by taking RG58 and the probe tip’s internal resistance into account in the measurement results.
Regards Andreas
Translation of “Der Wert ist oberhalb der maximalen Grenze für positive Zahlen” = “The value is above the maximum limit for positive numbers”
Versuch mit R und C mit Oszi.pdf (982.36 KiB)已下载 363 次。 The value is above the maximum limit for positive numbers.gif Versuch mit R und C mit Oszi.sm (131.13 KiB)已下载 547 次。
已编辑 2026/5/10 06:01:03
#5 已发布: 2026/5/10 08:15:12
StvMath
StvMath
44个赞和1个踩,共76个帖子。
"Why does the differential of V1(t) work, but not that of V2(t)?"
It's a combination of the size of the numbers and the order in which SMath does its calculations. Try:
#6 已发布: 2026/5/10 10:41:34
Andreas Beldowski
Andreas Beldowski
0个赞,共17个帖子。
Yeah, that's how it works for me, too.
#7 已发布: 2026/5/12 13:09:32
Andreas Beldowski
Andreas Beldowski
0个赞,共17个帖子。
It's me again, with a new problem.
Why doesn't the last line work, when the four lines above it do?
Versuch mit R und C mit Oszi Auszug.gif Versuch mit R und C mit Oszi Auszug.pdf (910.43 KiB)已下载 350 次。 Versuch mit R und C mit Oszi Auszug.sm (130.35 KiB)已下载 520 次。
#8 已发布: 2026/5/13 02:13:04
1,139个赞,共1,805个帖子。
Hi. I have no idea why it fails, however this may be a workaround, consisting of directly applying the Newton-Raphson method.
Versuch mit R und C mit Oszi Auszug.sm (121.16 KiB)已下载 505 次。
#9 已发布: 2026/5/13 05:47:01
Andreas Beldowski
Andreas Beldowski
0个赞,共17个帖子。
And why can I only use the values for LV1 and LV2 once, but the values for LdV1dt and LdV2dt multiple times?
I had already deleted the `clear()` statements, but that wasn't the problem.
已编辑 2026/5/13 05:48:52
#10 已发布: 2026/5/13 09:41:38
1,139个赞,共1,805个帖子。
Hi. Use eval:
