need help
need help - Messages
#1 Posted: 5/9/2026 8:35:16 AM
Andreas Beldowski
Andreas Beldowski
0 likes in 17 posts.
unfortunately, I can't find the error myself. Why VS(t) and VRG58(t) work well, but V1(t):=VS(t)-VRG58(t) not?
Regards Andreas
Auszug.pdf (114.69 KiB) downloaded 401 time(s).
Auszug.sm (16.52 KiB) downloaded 521 time(s).
#2 Posted: 5/9/2026 9:14:00 AM
127 likes in 342 posts.
It seems that the two quantities have different units of measurement.
#3 Posted: 5/9/2026 12:44:41 PM
Andreas Beldowski
Andreas Beldowski
Thanks Sergio,
wrong was VRG58(t):=Ig(t)*(1/ZLRG58+1/RRG58)
right is VRG58(t):=Ig(t)*(ZLRG58+RRG58)
Regards Andreas
#4 Posted: 5/10/2026 5:52:13 AM
Andreas Beldowski
Andreas Beldowski
and here’s another problem. Why does the differential of V1(t) work, but not that of V2(t)?
Both are sine functions; later, I’d like to try using square-wave functions as input as well.
For V1 and V2, I need the peak-to-peak amplitude and the phase difference between the two. I want to see if I can get better approximations for determining C1 by taking RG58 and the probe tip’s internal resistance into account in the measurement results.
Regards Andreas
Translation of “Der Wert ist oberhalb der maximalen Grenze für positive Zahlen” = “The value is above the maximum limit for positive numbers”
Versuch mit R und C mit Oszi.pdf (982.36 KiB) downloaded 357 time(s). The value is above the maximum limit for positive numbers.gif Versuch mit R und C mit Oszi.sm (131.13 KiB) downloaded 525 time(s).
Edited 5/10/2026 6:01:03 AM
#5 Posted: 5/10/2026 8:15:12 AM
StvMath
StvMath
44 likes and 1 dislikes in 76 posts.
"Why does the differential of V1(t) work, but not that of V2(t)?"
It's a combination of the size of the numbers and the order in which SMath does its calculations. Try:
#6 Posted: 5/10/2026 10:41:34 AM
Andreas Beldowski
Andreas Beldowski
Yeah, that's how it works for me, too.
#7 Posted: 5/12/2026 1:09:32 PM
Andreas Beldowski
Andreas Beldowski
It's me again, with a new problem.
Why doesn't the last line work, when the four lines above it do?
Versuch mit R und C mit Oszi Auszug.gif Versuch mit R und C mit Oszi Auszug.pdf (910.43 KiB) downloaded 346 time(s). Versuch mit R und C mit Oszi Auszug.sm (130.35 KiB) downloaded 501 time(s).
#8 Posted: 5/13/2026 2:13:04 AM
1,139 likes in 1,805 posts.
Hi. I have no idea why it fails, however this may be a workaround, consisting of directly applying the Newton-Raphson method.
Versuch mit R und C mit Oszi Auszug.sm (121.16 KiB) downloaded 490 time(s).
#9 Posted: 5/13/2026 5:47:01 AM
Andreas Beldowski
Andreas Beldowski
And why can I only use the values for LV1 and LV2 once, but the values for LdV1dt and LdV2dt multiple times?
I had already deleted the `clear()` statements, but that wasn't the problem.
Edited 5/13/2026 5:48:52 AM
#10 Posted: 5/13/2026 9:41:38 AM
Hi. Use eval:
