combining arrays
combining arrays - 消息
#1 已发布: 2022/1/11 11:21:07
1986max
1986max
0个赞,共9个帖子。
Tell me please.
Question - 1
There are several arrays. a=[1;2...4], b=[7;8..10], c=[12;13...15]
How do I combine them so that it turns out as follows - d=[1,2,3,4,7,8,9,10,12,13,14,15]
Question - 2
There is an array a=[1;2...10], I need to exclude several values from it so that it turns out as follows a=[1,2,5,6,7,9,10]
q-1-2.sm (3.71 KiB)已下载 1269 次。
#2 已发布: 2022/1/11 13:12:55
127个赞,共342个帖子。
One way (stack use)
q-1-2_ser.sm (6.18 KiB)已下载 1333 次。
Andrey Ivashov 2022/1/11 15:23:00
#3 已发布: 2022/1/11 13:51:29
983个赞,共6,866个帖子。
Question - 2
Make it algo style, add/remove cols.
This way you will have in-situ as desired.
Welcome to Smath Community ... Jean.
#4 已发布: 2022/1/12 03:58:49
1986max
1986max
0个赞,共9个帖子。
thank a lot, all options are excellent!)
#5 已发布: 2022/1/12 10:26:33
983个赞,共6,866个帖子。
Thank a lot, all options are excellent !
Appreciated ... more in there ... Jean.
Utilities Matrix Extractors.sm (56.76 KiB)已下载 1276 次。
sergio 2022/1/12 11:17:00
#6 已发布: 2022/1/14 15:06:20
600个赞,共1,381个帖子。
In addition to sergio's answer, you can use an custom exclude function.
It will remove substances of a L# list from master M# list.
exclude.sm (5.92 KiB)已下载 1218 次。
