Contour Integral Dummy Style
Contour Integral Dummy Style - Contour Integral Dummy Style - 消息
#1 已发布: 2018/12/10 13:39:00
983个赞,共6,866个帖子。
Can't manage this otherwise than shitting bricks !
Solution is welcomed ... Thanks
Done otherwise to rescue the Document.
Inst_PID Discrete Schema EXAMPLE_6 Failed.sm (36.61 KiB)已下载 1271 次。
#2 已发布: 2018/12/10 14:15:29
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Tiny fix
Inst_PID Discrete Schema EXAMPLE_6.sm (39.17 KiB)已下载 1234 次。
frapuano 2018/12/10 16:55:00
#3 已发布: 2018/12/10 15:55:07
Arie
Arie
94个赞,共285个帖子。
In order to pass functions as inputs to other functions you need to declare it as such and pass a "dummy" variable. See following.
There is still a problem in that it is not evaluating properly, I believe.
Inst_PID Discrete Schema EXAMPLE_6_Partlyfixed..sm (44.75 KiB)已下载 1264 次。
#4 已发布: 2018/12/10 20:29:36
1,443个赞,共2,936个帖子。
fixed
Inst_PID Discrete Schema EXAMPLE_6 - fixed.sm (46.19 KiB)已下载 1293 次。
2018-12-11 00_34_33-SMath Studio - [Inst_PID Discrete Schema EXAMPLE_6 - fixed.sm].png
  • removed answer requested for first argument of the last system;
  • used f(number_of_arguments) function of function argument (more elegant, point out that the variable name doesn't matter);
P.S. To obtain similar results, change the integration accuracy to something higher than 100
2018-12-11 00_53_52-SMath Studio - [Inst_PID Discrete Schema EXAMPLE_6 - fixed.sm_].png
Arie 2018/12/10 20:37:00
#5 已发布: 2018/12/10 23:05:36
Arie
Arie
94个赞,共285个帖子。
fixed
Dumb question maybe, but how do you get the '#' to show up in the H(#) function call?
#6 已发布: 2018/12/11 00:50:47
983个赞,共6,866个帖子。
As simple as that: x(n,X(▄)) ... simply the native dummy argument
big square imitation Alt220 ... try it.
Thanks all you Doctors ! Just refreshing that huge collection
of PID examples, coming soon.
#7 已发布: 2018/12/11 01:04:47
983个赞,共6,866个帖子。
... like this:
#8 已发布: 2018/12/11 04:44:48
1,443个赞,共2,936个帖子。
CTRL+K then #
:d
another option, yes
#9 已发布: 2018/12/13 19:02:18
1,139个赞,共1,805个帖子。
Hi. This is the setup for use inverse laplace transform for numerically evaluate the response for a system in z domain.
pid_controler z.sm (50 KiB)已下载 1271 次。
frapuano 2018/12/13 19:41:00
