Problem with opening the file
Problem with opening the file - I open the file and 5 sec later close and disappear itself - 消息
#1 已发布: 2021/7/1 07:01:43
alexa123
alexa123
0个赞,共1个帖子。
Podwojny balkon.sm (2.79 MiB)已下载 1606 次。
#2 已发布: 2021/7/1 07:43:41
600个赞,共1,381个帖子。
Here is your manually recovered file.
Apparently there was an empty text region.
It was starting at line 8662.
That was causing the error.
Removing it made the file tick.
Podwojny balkon1.sm (2.79 MiB)已下载 1650 次。
    <region left="342" top="56124" width="63" height="27" color="#000000" fontSize="12">
      <text lang="pol" width="55" fontFamily="Times New Roman" fontSize="12">
        <content>
          <p>  \[REGION[c655dfafd07249abba46f86987917195]]\[m2]</p>
        </content>
        <regions>
          <region id="c655dfafd07249abba46f86987917195" left="10" top="0" width="17" height="26" color="#000000" fontSize="12" />
        </regions>
      </text>
    </region>
#3 已发布: 2021/12/10 08:33:36
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
1个赞,共27个帖子。
        <content>
        </content>
        <regions>
        </regions>
      </text>
    </region>
good morning I'm having the same problem how do I open this msdos tab to fix?
