Incorrect Unit calculation
Incorrect Unit calculation - Incorrect Unit calculation - 消息
#1 已发布: 2015/1/31 23:11:42
nik
nik
0个赞,共8个帖子。
Hi all,
some problem which unit calculation
K:8.87
α:1
β:0.43
γ:0
b:200*'мм
Kα:K*(α+(β*{α^2}/{b^2})+(γ*{α^4}/{b^4}))^0.5=#
result: Unit does not match((((
#2 已发布: 2015/2/1 09:39:04
1,443个赞,共2,936个帖子。
The error seems correct. Just make a dimensional analysis on α+(β*{α^2}/{b^2})+(γ*{α^4}/{b^4})
You sum something dimensionless with 1/мм^2 and 1/мм^4
#3 已发布: 2015/2/2 19:45:39
nik
nik
0个赞,共8个帖子。
I`m not convert unit of measure, math operation only value. mm^4 you real?? what a dimension, square? cube or astral?
#4 已发布: 2015/2/2 20:11:26
1,443个赞,共2,936个帖子。
Maybe the attached picture helps a little bit more to understand the issue...
As stated previously, you can't sum apples and oranges; therefore the error message seems consistent...
#5 已发布: 2015/2/3 18:46:44
nik
nik
0个赞,共8个帖子。
ок,
formula
#6 已发布: 2015/2/3 19:20:22
1,443个赞,共2,936个帖子。
Thanks for sharing the original formula, this makes more sense; seems you have missed or merged a parameter (alpha) with a variable (a)
Best regards,
Davide
nik.sm (17.74 KiB)已下载 1412 次。
#7 已发布: 2015/2/4 18:04:59
nik
nik
0个赞,共8个帖子。
this is font trouble, real value "a"
#8 已发布: 2015/2/4 19:20:46
1,443个赞,共2,936个帖子。
Seems strange, because in this way the formula has both mathematical sense (alpha*x^0+beta*x^2+gamma*x^4) and physical sense (homogenous units involved in the calculation)... there is some literature about this formula? (where it is used? has an author?)
