system of equations
system of equations - 消息
#1 已发布: 2020/1/17 06:36:24
Ale16595
Ale16595
0个赞,共35个帖子。
Hi everyone, I have a problem with the equation system shown. does not return any results ... where am I wrong?
this is the .sm file sisstema.sm (59.73 KiB)已下载 1201 次。
#2 已发布: 2020/1/17 08:47:50
1,362个赞,共2,276个帖子。
You don't use the Solve() function correctly. The second argument is a list of variables (names), not a list of equations. Solve() is a symbolic procedure and doesn't need initial values.
In your case, there are two solutions because the variable V appears only squared.
Solve returns two lists of equations, which can be applied using Assign() for assignment of the solution variables.
4位用户喜欢此帖子
Ale16595 2020/1/17 09:03:00, frapuano 2020/1/17 09:48:00, sergio 2020/1/17 11:14:00, NDTM Amarasekera 2020/1/17 13:33:00
