Vectorize Issue: How to Get 2D Matrix Output? - 消息
.WroteDownload Kirby NIST data set ... fit.
I will correct your defective design.
Just that one for learning step.
WroteJust that one for learning step.
Yeah, you should learn there is no such thing as kW/hr.
Unit of power is kW, it is written as kilowatt. No time involved.
And poise is the unit of dynamic viscosity. (Pa*s) or (kg/m*s)
In pump calculation you should use stokes. (m^2/s)
Wrote.WroteDownload Kirby NIST data set ... fit.
It would have been a really fast learning step if SMath's units were used from the outset.
Time for an apology and a retraction (SI units being unsuitable for process control) Jean, me thinks.
This has not been pleasant to watch.
WroteTime for an apology and a retraction (SI units being unsuitable for process control) Jean, me thinks.
Yes Mark, adapt project system/standards,
accordingly to the Control Engineer Tool Box ... standards
Nothing dogmatic/Bible.
Cheers ... Jean.
Mark R Harris 2022/4/23 20:01:00
WroteWroteTime for an apology and a retraction (SI units being unsuitable for process control) Jean, me thinks.
Cheers ... Jean.
Excellent, thanks Jean.
It may be worth doing some weeding to remove examples that may lead noobies astray.
