wrong handling of units - Measure Units - 消息
NH.3_ex_c_r:NH.3_ex_c*M.ex_c=1227.6454 Gy tonne
NH.3_ex_c_r:NH.3_ex_c*M.ex_c=1.2276*10^6 J tonne
We'll need more information to help you. could you please post the .sm file you're referencing?
WroteNH.3_ex_c_r:NH.3_ex_c*M.ex_c=1227.6454 Gy tonne
"tonne" reminds me a Mathcad bug in the German version.
It also appeared in the Mathsoft "Fourier model" English US version.
WroteHi Adis,
Proiect master MB1.sm (38.93 KiB)已下载 1408 次。
WroteProiect master MB1.sm (38.93 KiB)已下载 1408 次。
In your file I can't find neither NH.3_ex_c nor M.ex_c
WroteWroteProiect master MB1.sm (38.93 KiB)已下载 1408 次。
Sorry wrong files.
Problem.sm (105.05 KiB)已下载 1415 次。
Real result is 1.2276 tone. 1 tone = 1000 kg
I have disabled some of your manual unit definition and performed some cleanup.
Generally you do not want to overwrite units already defined within Smath and you were re-defining already defined units.
The issue, I believe came with your definition of H.ii_c. You applied units to the result and toggled ignore units. This made it seem like the result evaluated to kJ/kg when in fact it was unitless.
This propagated through to the result in question.
Problem_alyles.sm (120.74 KiB)已下载 1423 次。
WroteI think i fixed the issue. See attached.
Above my head ! why do we still have tonne ?
For God sake what's that in Smath ?
What was it in Mathcad ?
What is the difference between "Titration and MassBalance" ?
In case of interest, PseudoInverse works fine in Smath.
Matrix PseudoInverse.sm (111.21 KiB)已下载 1431 次。
Wrote1 tonne is defined as 1000 kg. Same thing as a Mg.
Thnks alyless,
ton(long), ton(short), tonne(metric)
Thank you very much! The original file was worked in Mathcad. After conversion to SMath Studio, some errors occurred. In the future, I will only use the defined units.
WroteThank you very much! The original file was worked in Mathcad.
Oh !, you are the man of science in there.
I know about titration from past professional [Process Control & Instrumentation]
Not so easy ... so and so ... generally Ph control.
Did you visit PseudoMatrix ? Any use for your project ?
![2018-05-03 18_06_07-SMath Studio - [Page1_].png](/zh-Hans-CN/files/Download/EM4Pdc/2018-05-03-18_06_07-SMath-Studio---[Page1_].png)
