1页(9条)
Text Region Background Color - Bug when it contains a formula - 消息
Text region background color don't uniformly applied when it contains an inline formula.
This bug occurs on linux, don't know the current situation under windows.
textregion_bug.sm (3.03 KiB)已下载 1619 次。
Wrote... SS 6179
SMath v6179 don't have inline formula usage in text regions.
Your sample is useless for this bug, has wrong information.
WroteSMath v6179 don't have inline formula usage in text regions.
You can have it lot more productive for publishing Formatted Label.
WroteYou can have it lot more productive for publishing Formatted Label.
No I won't be more productive.
Bug is related with text region under latest smath releases.
There is no relevance with Formatted Label.
I demand you to stay with subject.
WroteBug is related with text region under latest smath releases.
Designers may appreciate You specify from which latest releases
No one uses old releases except you.
So when a new bug is defined it is either in last stable or nightly build.
Developers know what to do, they don't need your suggestions to understand.
1页(9条)
