SMath论坛 SMath Studio Bugs & Problems pdf plugin export filename 1页(2条) pdf plugin export filename - After doing a pdf export, the filename becomes xxx.pdf, not xxx.sm - 消息 转到最后一个帖子 #1 已发布: 2014/12/9 04:14:44 crun2 0个赞,共10个帖子。 组: User After doing a pdf export, the filename displayed on the title bar becomes xxx.pdf, not xxx.sm.When you close SM it is unable to save the sm file, until I saveas SM again. #2 已发布: 2014/12/9 08:42:11 brotjob 7个赞,共71个帖子。 组: User I can confirm this. I opened a issue in the issue tracker: Unable to safe after pdf export 1页(2条) 有新帖 无新帖
