Precision on NonLinear Solvers
Precision on NonLinear Solvers - How enhance precision of solution? - Messages
#1 Posted: 2021/10/9 14:51:57
Roman2302
Roman2302
0 likes in 3 posts.
Hi, I want to know what is the method of enhance precision in numerical solution into plugin Nonlinear Solvers.
Precision.sm (12.95 KiB) downloaded 991 time(s).
#2 Posted: 2021/10/9 15:14:52
There is method unless some reference from source.
Some solvers work more accurately then others.
Generally, they will range from 4 decimals to 15 decimals.
Some functions are so involved in numerical error propagation
that you will have to refine the search range ... Goat radius.
Cheers ... Jean.
Precision.sm (20.77 KiB) downloaded 984 time(s).
#3 Posted: 2021/10/9 15:34:37
Roman2302
Roman2302
0 likes in 3 posts.
Yes, using a initial values more accurately I have a better precision. Thanks so much
#4 Posted: 2021/10/9 20:04:59
Another example, much different solver.
15 decimals in Engineering works makes no sense
Cheers for your profitable application(s) ... Jean.
Precision Solve.sm (47.69 KiB) downloaded 950 time(s).
#5 Posted: 2021/10/10 09:20:41
... both high accuracy solvers in same document.
Your stuff collapsed/disabled.
Occasionally, roots(2), roots(3) are profitable.
Precision Solve.sm (68.45 KiB) downloaded 968 time(s).
sergio 2021/10/10 12:52:00
#6 Posted: 2021/10/10 13:59:37
Roman2302
Roman2302
0 likes in 3 posts.
Thanks so mucho
