Maxima Draw 2D
Maxima Draw 2D - Question about Maxima Draw 2D - 消息
#1 已发布: 2021/12/23 15:28:05
PE_Electron
PE_Electron
0个赞,共3个帖子。
I am a new user of SMath. I mainly use it for control system analysis and drawing Bode plots for transfer functions.
I am trying to figure out how to change the marker for different curves. I use Maxima plugin.
Please see my attached file.
ThanksTF.sm (53 KiB)已下载 1352 次。
#2 已发布: 2021/12/23 19:51:15
983个赞,共6,866个帖子。
#3 已发布: 2021/12/23 21:07:33
PE_Electron
PE_Electron
0个赞,共3个帖子。
Thanks for your reply.
What I was trying to figure out is how to change the marker point for curves for better visualization. I could find out how to changes the line width and color in Maxima as you can see in my file.
It is easy to do it with X-Y plot but I needed log scale and it is available in Maxima.
#4 已发布: 2021/12/23 21:52:06
1,139个赞,共1,805个帖子。
Hi. Use line_type≡dashes. Other types are dots, short_dashes, short_long_dashes, short_short_long_dashes and dot_dash
2位用户喜欢此帖子
Oscar Campo 2021/12/23 23:40:00, sergio 2021/12/24 06:58:00
#5 已发布: 2021/12/24 00:40:56
PE_Electron
PE_Electron
0个赞,共3个帖子。
Thanks so much. This is helpful.
Is there a manual where I can find these different settings and options?
#6 已发布: 2021/12/24 01:15:16
1,139个赞,共1,805个帖子。
https://maxima.sourceforge.io/docs/manual/
