[X-Y Plot plugin] region dissappears when ploting
[X-Y Plot plugin] region dissappears when ploting - 消息
#1 已发布: 2016/6/24 19:45:22
Basile
Basile
8个赞,共172个帖子。
X-Y plot plotting two functions:
Basile
#2 已发布: 2016/6/24 21:35:35
1,139个赞,共1,805个帖子。
Hi Basile. A bug without the file could be hard to interpret.
But, unregarding math or bugs, you're trying to use negative frequencies. Are you sure about what could be represent that? Also, a zero frequency, what is it? Direct current?
Frequencies also are usually represented in a log scale.
#3 已发布: 2016/6/24 22:42:36
Basile
Basile
8个赞,共172个帖子。
Alvaro,
All you say about the physics of the problem, you are right.
But look the mathematics, just plotting a function.
Look above, the X.L(f) plots fine.
Similarly plots fine if I use the Plot-2D.
Basile
#4 已发布: 2016/6/24 23:19:22
1,139个赞,共1,805个帖子。
Hi Basile. You discover a couple of nice and unwanted visual special effects in blue. I know near nothing about smath plugins, and can't help about them.
#5 已发布: 2016/6/25 00:38:12
983个赞,共6,866个帖子。
Two things Basile:
1. Your unit systen is wrong [L => H, C => F]
2. Xc, XL have nothing to do with an LC circuit.
XL is equal to f(x):= dontknow*x
XC is equal to f(x):= 1/dontknow*x
https://en.wikipedia.org/wiki/LC_circuit
#6 已发布: 2016/6/25 09:38:01
Basile
Basile
8个赞,共172个帖子。
Jean,
My system of units is NOT wrong.
Capacitance in Farad
Inductance in Henry
Reactance of both in Ohm.
Basile
#7 已发布: 2016/6/26 07:51:00
1,443个赞,共2,936个帖子。
Seems the issue is related to negative infinity
#8 已发布: 2016/6/26 09:18:34
983个赞,共6,866个帖子。
Basile,
What you did is no not correct: You copied the L
plot and put in it the C plot with the same L scales.
So, the C plot flies in the blue. Someting like this:
If you photograph a mouse and an elephant in the same
bed, you won't see both. If you adjust for elephant,
the mouse will be a dot pretty hard to isolate and
enlarge unless you have zillions of MP resolution ...
#9 已发布: 2016/6/26 09:27:34
983个赞,共6,866个帖子。
Forum Basile Plot.sm (4.95 KiB)已下载 1335 次。
#10 已发布: 2016/6/26 14:31:03
Basile
Basile
8个赞,共172个帖子。
Jean,
Yes, it works with the Plot 2D.
The problem is with the X-Y plot. It disappears and freezes the instance of Smath!
As pointed by Davide a possible problem with minus infinity?
Basile
#11 已发布: 2016/6/26 16:05:08
983个赞,共6,866个帖子。
NO => Not as you think. X_Y is not an autoplot, it is a plot range.
If you plot sin(x) it falls in its default XY ranges OK. Otherwise
you have to range both directions. X_Y does not supports few things:
1. It does not plot x. It does not understand that 'x' is implicit
of 'x' = "1*x" neither implicit of 'x' = 'x+0'
2. It supports some common Engineering ranges 1*e ±3 [per say]
but will crash Smath instance if you want to range 1*e ± -15
X_Y is lovely in many projects but not in others.
#12 已发布: 2016/6/29 13:02:35
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
By increasing the limit values of the function  the graph does not
pass through a pivotal point
Bug.sm (8.2 KiB)已下载 1354 次。
#13 已发布: 2016/6/29 14:31:53
983个赞,共6,866个帖子。
That's right but not a bug. Just that above the Y magnitude 45,
the canvas misses some points in the critial region.
More: does not fill the circle, plots x instead of +
X_Y Plot wisely.sm (11.2 KiB)已下载 1379 次。
Fridel Selitsky 2016/6/29 14:37:00
#14 已发布: 2016/6/29 14:38:02
983个赞,共6,866个帖子。
