1页(7条)
Plugin for reading results from civil eng. FE model - Plugin for reading results from civil eng. FE model - 消息
Hello all,
I wrote a plugin for SMath Studio that was released as open-source here.
I uses API from a free program for structural FE analysis to extract results. By now, reactions, displacements and beam forces are supported. Results are given with proper units of measure.
I found only outdated PDF instructions on what to do for submitting the plugin to SMath online catalog - the site forced me to use "Release Manager" and I don't know how to proceed to request plugin approval (ie. svn path??).
Can anyone give some hints?
thanks in advance
ps.
any suggestion or change on plugin is welcome - see also this post for warning messages if used in .exe file
thanks in advance
ps.
3位用户喜欢此帖子
Anyone on how to use "Release Manager" or on how to proceed to request plugin approval?
thanks
thanks
You need to contact with Andrey. I asked him to help you.
johnnyontheweb 2021/10/1 02:53:00
Hello, [USERLINK]johnnyontheweb[/USERLINK]
Release Manager works with internal project repository (SVN) only.
Please contact me by e-mail - I will provide a login/pw for you. You will be able to use Release Manager as soon as the code is there.
Best regards and thanks for your work!
johnnyontheweb 2021/10/6 10:14:00
Thanks, I sent you an email a few days ago.
best regards
best regards
WroteThanks, I sent you an email a few days ago.
best regards
Did you receive my answer to you (sent on 2 Oct)?
If not, I will duplicate it in PM here on the forum.
Thanks, now I reveived in PM.
1页(7条)
