Mobius Strip
Mobius Strip - Mobius Strip - 消息
#1 已发布: 2017/6/8 09:20:52
983个赞,共6,866个帖子。
Not very glorious, the twisted path is observable.
Snippet is too large size to be attached.
A < 5 min visit ... Jean
Rotate Mobius.sm (29.28 KiB)已下载 1433 次。
#2 已发布: 2017/6/8 15:11:46
алексей
алексей
17个赞,共78个帖子。
Some examples with Mobius Strip (However, in Maple)
http://www.mapleprimes.com/posts/207879-Rolling-Without-Slipping-On-A-Nonorientable
#3 已发布: 2017/6/8 21:36:33
983个赞,共6,866个帖子。
http://www.mapleprimes.c...pping-On-A-Nonorientable
Thanks "Kamarad" for the link. Interesting visit.
The attached has no animation, 100 mesh.
Rotate Mobius Orient.sm (120.89 KiB)已下载 1384 次。
#4 已发布: 2017/6/9 05:08:12
алексей
алексей
17个赞,共78个帖子。
If you have problems with the size of the animation to display in your posts, I can recommend, if you do not know, a small program "Easy GIF Animator". This program is very convenient for demonstrating the animation, because it can reduce the size of the .gif file by several times and even more (without loss of quality).
I, for example, do not have SMath, but sometimes I want to see the result of professional work.
Thank you.
#5 已发布: 2017/6/11 15:42:29
алексей
алексей
17个赞,共78个帖子。
Another example. Additional torsion of the Mobius Strip
(The .gif file was almost 6 Mb in size, and after processing with the program "Easy GIF Animator" became almost 55 KB)
https://vk.com/doc242471809_446439002?hash=a24d750a83896a7df8&dl=907bc6a2fa42c96149
#6 已发布: 2017/6/12 09:28:45
983个赞,共6,866个帖子。
Thanks from Russia for the Quick link ... lovely from Maple.
#7 已发布: 2017/6/12 13:24:57
алексей
алексей
17个赞,共78个帖子。
Thank you for your kind words.
If it is interesting, here is the place where today the text of the last Maple program (Möbius strip ) appeared.
http://www.mapleprimes.com/posts/207879-Rolling-Without-Slipping-On-A-Nonorientable#comment202478
