DISCARDED: SMath Studio 0.99.6647 (14 March 2018) - Messages
List of changes (between 0.99.6646 and 0.99.6647 versions)
Improvements
- Support for Shift+Enter keystroke (in addition to Ctrl+Enter) added for equations breaking;
- F11 keystroke handles Step In functionality now;
- Close button added to Debugging/Output panels;
- SS-2322: Ctl+A keystroke enabled into Output window.
Corrections
- Displayed error occurred on incorrect break/continue usage fixed;
- Rendering of range(..) functions corrected;
- Slow performance of el(..) function in some cases when working with complex numeric expressions fixed;
- Inserting 'i' char after apostrophe symbol or as a first function's name letter fixed;
- SS-3511: Rendering of boolean equal operator improved;
- Result matrix resize symbols made agnostic to fonts available on the machine;
- Symbolic engine error causes evaluation abort fixed;
- Refactoring of the Calculation logic in a separate system thread performed (errors related to manual termination of the evaluation fixed);
- Mouse wheel handling by regions in Pages View mode fixed (it was impossible to use mouse wheel over some parts of the focused region);
- Replacing of function existing on the worksheet with another one using Dynamic Assistance list fixed;
- Select All (or Ctrl+A) inside a Worksheet allowed now when Calculation is in progress;
- Loading of the program became faster on some environment configurations.
Miscellaneous
- Errors handling logic reworked;
- Interface translations updated;
- Refactoring.
Download
SMathStudioDesktop.0_99_6647.Mono.tar.gz (1.28 MiB) downloaded 2452 time(s).
SMathStudioDesktop.0_99_6647.Setup.msi (2.15 MiB) downloaded 4640 time(s).
SMathStudio 0.99.6646 and 0.99.6647 discarded due to serious bug with colapsed areas, which could damage your worksheet data.
Sorry for inconvenience. Working to fix it asap!
WroteuMath Files Plugin appears to be broken with new release.
Thank you! Fixed and new plug-in version uploaded.
Thanks,
Jason
WroteArea controls seem to have been adversely affected with this build.
Please could you send a file to me by e-mail to fix? I cannot reproduce this issue on any of my worksheets.
In my case, when the sheet is opened, the problem does not exist but after saving the sheet, after closing it and finally reopening, problems with the collapsed areas occur.
C6 Channel Shear Tab.sm (228.91 KiB) downloaded 1656 time(s).
Do you have the initial version?
WroteI experienced problems similar to those of Jason.
Sergio, seems this is very important issue. And bug is in saving logic.
Please could you provide any file which gives this error on save?
Thanks in advance!
Jason
Channel Shear Tab.sm (228.88 KiB) downloaded 1604 time(s).
I've reproduced this issue and it is introduced exactly in 0.99.6646.
I'm working to figure out the reason and fix it asap.
The following SMath Studio nightly builds are marked as NOT APPROVED and will not be suggested to download to anyone anymore: 0.99.6646, 0.99.6647!
Thank you very much for the report and your help!
