Strange behavior with temperature units
Strange behavior with temperature units - Messages
#1 Posted: 12/26/2020 5:22:32 PM
Anders or Eric
Anders or Eric
4 likes in 40 posts.
Hi- I've found an inconsistency when working with temperature units other than an absolute scale.
If I enter a number and multiply by either Fahrenheit or Celsius (°F or °C), the units are applied as I expect.
If I define a variable and assign a value to it, and then multiple by °F or °C, I get an error saying that the variable is not defined. It clearly is defined though, since performing other operations (multiplication, addition, assigning absolute scale temperature units, etc.) works as expected on the variable.
If I make a user-defined version of the temperature unit, assigning it to itself, and then apply the unit to the variable, it works okay.
Can anyone confirm this? I’m using the Mono version of release 7610 on Linux.
temp_bug.sm (4.74 KiB) downloaded 1524 time(s).
#2 Posted: 12/26/2020 7:14:59 PM
I can only confirm you are wrongdoing !
t:=*type' insert°C from unit drop down menu
t:=59*'°C ... t=59°C
#3 Posted: 12/26/2020 8:00:03 PM
Anders or Eric
Anders or Eric
Thanks Jean, but it's not my intent to invite critique on my procedure. I've posted a bug report to see if this is a known issue that might be fixed. I understand you have no way to know why I want to go about the assignment in this order, but hopefully it will suffice to say that I have my reasons, and we can avoid side-tracking the topic.
The method I show works fine for any other units I've tried so far, and creating the user-defined °F causes problems in other conversions. I haven't checked earlier versions or non-Mono versions so I don't know how much hope to hold out for a fix, or whether I should just work entirely with absolute temperature units. If anyone has insight on what's going on it would be much appreciated.
Thanks very much,
Eric
#4 Posted: 12/26/2020 9:20:01 PM
1,139 likes in 1,805 posts.
Hi. It seems that Fahrenheit degrees clears t.
Yep. On Windows 10.
#5 Posted: 12/26/2020 11:59:38 PM
Anders or Eric
Anders or Eric
Thanks very much for looking at that Alvaro. I had only tried numeric evaluation- I get the same result as you with symbolic evaluation.
It looks like you are in even worse shape than I am. The variable is still set to the original value for me after attempting to get a Fahrenheit value from it.
#6 Posted: 12/27/2020 8:03:02 AM
599 likes in 1,381 posts.
Same in here with Mono.
#7 Posted: 12/27/2020 9:46:25 AM
Eric,
At my age [no more a spring chicken], I hardy heard °F, °K.
1. ITS-90 [International Temperature Scale] primary fixed points are °C
2. Secondary standard BIPM Pt100 is in °C ... at higher temperature too.
You can work user as suggested.
