Angles in sexagesimal units?
Angles in sexagesimal units? - Messages
#1 Posted: 2/23/2019 8:57:11 AM
gskelly
gskelly
0 likes in 7 posts.
Is there a way to use SMath so that, at face value, the document has angular values expressed in degrees, minutes and seconds?
My inputs and outputs for all angular quantities are in sexagesimal units and may include decimals of a second.
Thanks
#2 Posted: 2/23/2019 9:59:32 AM
Maths Convert [deg, min, sec].sm (7.77 KiB) downloaded 885 time(s).
#3 Posted: 2/23/2019 11:05:28 AM
gskelly
gskelly
0 likes in 7 posts.
Thanks Jean. I understand your response to mean I will have to define functions to convert between the sexagesimal and decimal representations. Ideally I was hoping there was some way to use units.
The list approach would be preferred to the string since it would be easier to use as input. The function will need to handle negative values and test for cases where the floating point number representation may cause problems.
#4 Posted: 2/23/2019 11:40:29 AM
gskelly
gskelly
0 likes in 7 posts.
The negative values are easy to handle. Maybe the program handles the imprecision of floating point numbers automatically?
Maths Convert [deg,min,sec]-gds.sm (11.54 KiB) downloaded 867 time(s).
#5 Posted: 2/23/2019 12:16:22 PM
1,123 likes in 1,795 posts.
Hi. Here, my workaround.
DMS.sm (17.67 KiB) downloaded 1065 time(s).
frapuano 2/23/2019 12:28:00 PM, sergio 2/23/2019 6:26:00 PM
#6 Posted: 2/23/2019 1:58:25 PM
gskelly
gskelly
0 likes in 7 posts.
Hmmm... The separate units use is interesting. I am so inexperienced with SMath I can't figure out how to enter the summation portion.
I think I will need to leave the negative angle input as [ -d -m -s ] with this approach. Would you agree?
#7 Posted: 2/23/2019 2:02:52 PM
gskelly
gskelly
0 likes in 7 posts.
Ah-ha! The vectorize function.
#8 Posted: 2/23/2019 2:06:06 PM
Hi. Try this as general rule for SMath sintaxis:
Guess yes:
