Smath Studio 98.6606 closes unexpectedly
Smath Studio 98.6606 closes unexpectedly - Smath Studio quits unexpectedly when inserting a table and running the program - Messages
#1 Posted: 2/5/2018 10:07:46 PM
CBG
CBG
78 likes in 312 posts.
Smath Studio fails when a table containing arrays is inserted, and closes unexpectedly.
Test_Table.sm (6.37 KiB) downloaded 1225 time(s).
Davide Carpi 2/7/2018 8:58:00 AM
#2 Posted: 2/5/2018 11:37:06 PM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Hello CBG!
It works for me.
#3 Posted: 2/6/2018 1:55:54 AM
Hello CBG!
It works for me.
Carlos, try this
#4 Posted: 2/6/2018 5:04:41 AM
599 likes in 1,381 posts.
Works with Portable 6484
Force Close with installed 6606.
#5 Posted: 2/6/2018 5:24:53 AM
127 likes in 342 posts.
It works for me too.
I note that the variables of Carlos are not in italic character.
#6 Posted: 2/6/2018 8:47:42 AM
may be this helps better to understand the situation here.
correction: force close occurs if the first element of matrix is a string.
table_test2.sm (23.06 KiB) downloaded 1343 time(s).
#7 Posted: 2/6/2018 1:38:28 PM
CBG
CBG
Hello "ndtm", Jean, "overlord" and Sergio.
Thank you very much for your comments, recommendations, suggestions and help.
It seems that it is a Bug in Smath Studio 0.98.6606, since I tested it in the
versions of Smath Studio 0.98.6179, 98.6484 and 0.97.5346, and in
these versions it worked correctly.
#8 Posted: 2/6/2018 2:59:54 PM
2,343 likes in 4,055 posts.
I can't reproduce this issue with 6606.
#9 Posted: 2/6/2018 3:24:36 PM
Did you try updated version of Table Region?
#10 Posted: 2/6/2018 5:14:52 PM
Here is the latest deal, I have created a portable 6606 version which has no extension plugin except table region.
Now the table plugin is working as it should be. Maybe one of the installed plugins is creating the havoc.
I am going to try to find it by installing one at a time.
#11 Posted: 2/6/2018 5:31:16 PM
CBG
CBG
By---->Andrey Ivashov
Yes I Yes, I did it
Andrey Ivashov 2/6/2018 6:05:00 PM
#12 Posted: 2/6/2018 5:56:29 PM
Andrey,
Could you please change your decimal symbol from comma to period and try to open the test file above?
I think I have found the culprit. When I change it to comma, no issues so far.
#13 Posted: 2/6/2018 6:04:55 PM
Thank you very much! I will check decimal symbol and will try to fix the plugin asap.
#14 Posted: 2/6/2018 7:21:15 PM
Issue is reproduced. Working to investigate and fix.
#15 Posted: 2/6/2018 8:16:31 PM
Please could you try to update plug-in and test your examples?
I think I have fixed the issue.
CBG 2/6/2018 8:42:00 PM, Davide Carpi 2/7/2018 4:10:00 AM
#16 Posted: 2/6/2018 8:21:20 PM
Table region is not causing force crash.
Everything seems good, congrats.
Andrey Ivashov 2/6/2018 8:22:00 PM, CBG 2/6/2018 8:42:00 PM
#17 Posted: 2/6/2018 8:41:25 PM
CBG
CBG
Now the example works very well.
Thank you very much.
