Plugin Errors
Plugin Errors - Portable app errors with plugins - Messages
#1 Posted: 3/13/2026 12:05:13 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
Long time user, I've been away from maths for a bit. I tend to use the portable version of SMATH and was surprised that the following plugins would not load. I have several worksheets that use the plugins and was wondering if they are now "redundant" as they are part of the core program or if I need to do something different
#2 Posted: 3/16/2026 3:48:49 PM
1,442 likes in 2,933 posts.
Hello Ruben,
Since the extensions manager is no longer available for older versions, you have to download and install the plugins manually (downlad the zip, the drag & drop in the canvas), going back to an appropriate release date.
The link to download any plugin version is this: https://smath.info/{LOCALIZATION}/view/{PLUGIN_ID}/history
Plugins' IDs can be found in the heaader of any worksheet where you used it (using a text editor). Localization is the one that is visible in your browser when you browse the forum.
Edited 3/16/2026 4:25:41 PM
#3 Posted: 3/24/2026 8:44:38 PM
Ruben Sidranski
Ruben Sidranski
Davide,
Thank you for the quick reply. I have the latest SMath (Portable) on my flash drive. Does this mean I have to "re-download" all of my plugins? I've been away for a while so I likely missed the message from an update
#4 Posted: 3/25/2026 9:44:19 AM
My bad, I thought you had a 0.* version.
However seems you neither using the latest version too, since I see the error is somehow related to MathRegion 1.11.8763.0 that is part of SMathStudio 1.1.8763.
However in both these versions I cannot replicate the issue (at least with a fast check).
Since with these versions you can rely on the Gallery, I suggest you to:
  1. Make a copy of the "extensions\plugins" subfolder in your portable app directory
  2. delete that plugins subfolder
  3. install the plugins from the gallery again
Edited 3/25/2026 9:47:18 AM
