Plugin Errors
Plugin Errors - Portable app errors with plugins - Сообщения
#1 Опубликовано: 13.03.2026 12:05:13
Ruben Sidranski
Ruben Sidranski
Long time user, I've been away from maths for a bit. I tend to use the portable version of SMATH and was surprised that the following plugins would not load. I have several worksheets that use the plugins and was wondering if they are now "redundant" as they are part of the core program or if I need to do something different
#2 Опубликовано: 16.03.2026 15:48:49
1 438 сообщений из 2 920 понравились пользователям.
Hello Ruben,
Since the extensions manager is no longer available for older versions, you have to download and install the plugins manually (downlad the zip, the drag & drop in the canvas), going back to an appropriate release date.
The link to download any plugin version is this: https://smath.info/{LOCALIZATION}/view/{PLUGIN_ID}/history
Plugins' IDs can be found in the heaader of any worksheet where you used it (using a text editor). Localization is the one that is visible in your browser when you browse the forum.
Отредактировано 16.03.2026 16:25:41
#3 Опубликовано: 24.03.2026 20:44:38
Ruben Sidranski
Ruben Sidranski
Davide,
Thank you for the quick reply. I have the latest SMath (Portable) on my flash drive. Does this mean I have to "re-download" all of my plugins? I've been away for a while so I likely missed the message from an update
#4 Опубликовано: 25.03.2026 09:44:19
My bad, I thought you had a 0.* version.
However seems you neither using the latest version too, since I see the error is somehow related to MathRegion 1.11.8763.0 that is part of SMathStudio 1.1.8763.
However in both these versions I cannot replicate the issue (at least with a fast check).
Since with these versions you can rely on the Gallery, I suggest you to:
  1. Make a copy of the "extensions\plugins" subfolder in your portable app directory
  2. delete that plugins subfolder
  3. install the plugins from the gallery again
Отредактировано 25.03.2026 09:47:18
