DotNumerics
DotNumerics - Initial-value problem for nonstiff and stiff ordinary differential equations ODEs - Messages
#21 Posted: 8/1/2018 12:54:24 PM
1,558 likes in 1,868 posts.
Simple test 2.
DotNumerics.ode.test2.sm (21.23 KiB) downloaded 1769 time(s).
DotNumerics.ode.test2.pdf (79.99 KiB) downloaded 880 time(s).
sergio 8/1/2018 6:06:00 PM, Radovan Omorjan 8/2/2018 3:05:00 AM
#22 Posted: 8/1/2018 9:57:14 PM
Simple test 2.
Works nice conventional/visual [6179].
That document, if it would come from other designer
would pass my QA [Quality Assurance].
DotNumerics.ode.test2.sm (24.51 KiB) downloaded 1866 time(s).
#23 Posted: 9/9/2018 2:23:36 PM
1,361 likes in 2,275 posts.
It seems that all the dotnumeric ode solver functions fail to add the last step to the solution. In the given example, the exact solution is (approximately) met if the end value of x is increased by one step (x_end/steps).
The sheet is easily extended to whatever ode solvers by adding their name to the search list. The actually available solvers depend on what plugins are installed.
Section Math ODE precision.sm (23.66 KiB) downloaded 1921 time(s).
frapuano 9/9/2018 5:18:00 PM, Вячеслав Мезенцев 9/10/2018 5:37:00 AM
#24 Posted: 9/10/2018 6:48:25 AM
Updated for SS 0.99.6824. Intervals issue fixed.
3 users liked this post
sergio 9/10/2018 7:02:00 AM, frapuano 9/10/2018 9:23:00 AM, NDTM Amarasekera 9/10/2018 9:48:00 AM
#25 Posted: 12/6/2018 2:42:53 PM
Updated.
Changes:
- zero point issue fixed;
- added support for the simple D(t,x) definition.
#26 Posted: 12/24/2018 9:13:53 AM
Updated.
2018-12-24_17-06-48.png 2018-12-25_04-33-23.png 2018-12-25_04-34-24.png dn.ode.test2.png dn.ode.test1.png 2018-12-24_17-07-41.png
dn.ode.kinetic1.sm (8.26 KiB) downloaded 2022 time(s).
dn.ode.kinetic2.sm (12.59 KiB) downloaded 1888 time(s).
dn.ode.kinetic3.sm (12.28 KiB) downloaded 1966 time(s).
dn.ode.test1.sm (19.58 KiB) downloaded 1969 time(s).
dn.ode.test2.sm (18.88 KiB) downloaded 1946 time(s).
dn.ode.Amplitude detector.sm (20.17 KiB) downloaded 1995 time(s).
dn.ode.kinetic1.pdf (77.42 KiB) downloaded 1114 time(s).
dn.ode.kinetic2.pdf (93.05 KiB) downloaded 1043 time(s).
dn.ode.kinetic3.pdf (91.31 KiB) downloaded 1032 time(s).
dn.ode.test1.pdf (115.72 KiB) downloaded 1016 time(s).
dn.ode.test2.pdf (120.44 KiB) downloaded 998 time(s).
dn.ode.Amplitude detector.pdf (148.87 KiB) downloaded 1052 time(s).
4 users liked this post
NDTM Amarasekera 12/24/2018 9:44:00 AM, sergio 12/24/2018 11:04:00 AM, frapuano 12/24/2018 2:23:00 PM, Radovan Omorjan 12/24/2018 2:52:00 PM
#27 Posted: 12/25/2018 2:49:08 PM
Native works as well.
You can try rkfixedSteven.
#28 Posted: 12/25/2018 4:25:11 PM
frapuano 12/25/2018 7:01:00 PM
#29 Posted: 12/9/2021 9:10:25 AM
SMath Studio compatibility
Plugin updated.
Changes:
- added support the mathematical form of the problem for ODE solvers;
- refactored.
sergio 12/9/2021 11:40:00 AM
#30 Posted: 12/20/2021 4:18:13 PM
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
#31 Posted: 8/21/2022 2:43:28 AM
1,139 likes in 1,805 posts.
Hi Viacheslav. There are an issue with Implicit and dn_ExplicitRK45, just in the first element. Please see the attached.
dn_ExplicitRK45 issue.sm (8.42 KiB) downloaded 1772 time(s).
Вячеслав Мезенцев 8/22/2022 3:11:00 AM
#32 Posted: 8/22/2022 3:12:45 AM
Plugin updated.
Changes:
- fixed values of initial conditions in the output array for dn_ImplicitRK5() and dn_ExplicitRK45().
sergio 8/22/2022 4:19:00 AM, Alvaro 8/23/2022 8:15:00 PM
