1 Pages (16 items)
Operation with units xy2pol - Messages
#1 Posted: 6/5/2016 12:07:03 AM
#2 Posted: 6/5/2016 1:34:47 PM
#3 Posted: 6/5/2016 1:53:42 PM
Jean,
In your example:
The Magnitude (length) and The Angle (angle) in polar coordinates have different units. The rad is not a common unit. It is not correct.
In my example:
Look again please:
This was solved in recent upgrade by Andrey but apparently remains in the xy2pol.
http://en.smath.info/forum/yaf_postst7552_Units--Operation-cannot-be-performed.aspx
Basile
In your example:
In my example:
Look again please:
Basile
#4 Posted: 6/5/2016 3:14:46 PM
Better be in harmony wth the maths and Smath.
There is nothing to look gain, Smath is OK.
For sure they have different units: one is in "UnitGraph" the other is in "rad"
YES: rad is correct, rad is the maths unit in trig approximations as well as in official tables.
If you want °: convert by appending ° in the Smath result
#5 Posted: 6/5/2016 5:22:05 PM
Jean,
1.
Please go previously and see the picture.
"rad" is the unit for both the magnitude and angle.
There is ONE placeholder for ONE unit.
YES: rad is correct, [YOU JUST SAID THAT ONE IS LENGTH THE OTHER ANGLE!!!] rad is the maths unit in trig approximations as well as in official tables.
2.
In this specific set of applications I have no interest in "numerical MathEMATICS". I use units. Thank you.
Basile
1.
2.
Basile
#7 Posted: 6/5/2016 5:52:10 PM
Mike,
The xy2pol does not work when units are included:
Do we agree?
When eventually it is working:
The units of the "Magnitude" and the units of the angle, (for the case of complex numbers here), will be different.
Note: I see you got W(att) how?
I see that you have a semicolon ( ; ) I have a comma (,).
Re(S);Im(S) versus Re(S),Im(S)
Basile
Do we agree?
Basile
#9 Posted: 6/5/2016 7:55:50 PM
WroteMike,
Do we agree?
Yes we do
QuoteWhen eventually it is working:
Yes, that's what I show in my screenshot, that uses ≡ instead of =, just to show the desired result: seeing is better than reading.
QuoteNote: I see you got W(att) how?
Now I suppose it's apparent: Ctrl+= and manually make system with desired result
QuoteI see that you have a semicolon ( ; ) I have a comma (,).
Russian locale default settings
С уважением,
Михаил Каганский
#10 Posted: 6/5/2016 7:57:34 PM
In this specific set of applications I have no interest in "numerical MathEMATICS". [Basile]
From A...Z, Smath is a numerical math tool as any other CAS and including your specific application.
xy2pol result is a vector of two components that need no unit as they are implicit. Extract each
component and append a dead unit decoration for clarity to yourself and the reader.
#11 Posted: 6/5/2016 8:03:39 PM
WroteNotice that atan2 ins't in SMath, which is more correct than atan for this functions (see http://www.mathworks.com/help/matlab/ref/atan2.html for example).
atan2.sm (35.42 KiB) downloaded 1232 time(s).
С уважением,
Михаил Каганский
#12 Posted: 6/5/2016 8:58:58 PM
Hi Mike. I prefer this other, but have some round inconvenients:
#13 Posted: 6/5/2016 9:04:35 PM
WroteI guess that with the new try function samebody can make a good one atan2.
But with try, it won't differentiate again.
С уважением,
Михаил Каганский
#14 Posted: 6/5/2016 9:10:02 PM
WroteWroteI guess that with the new try function samebody can make a good one atan2.
Oh, I think that this happen only to me :-). Not very sure that try don't accept diff.
So, this with numerical optimization must to be the best solution (until atan2 not be in SMath):
#15 Posted: 6/5/2016 9:24:33 PM
It's a good option, and only ~30% slower.
С уважением,
Михаил Каганский
#16 Posted: 6/6/2016 10:11:40 AM
Like this Alvaro: look for the Matlb code in the f(x) menu,
look for mwatan2 ... if you have in your version: then go
Maths atan2.sm (10.93 KiB) downloaded 1272 time(s).
1 Pages (16 items)
