1 Pages (14 items)
solve & roots with units - Messages
#1 Posted: 6/3/2023 8:48:30 AM
#2 Posted: 6/3/2023 3:37:44 PM
WroteI can it solve in Mathcad - see please mcdx and pdf files
I try solve it (heat transfer) in SMath - see sm file
Help please
SMath symbolic solving of integration is not capable as Mathcad.
Thus integrals can't be used with numeric solvers.
However, you can use a little trick to solve them.
Using maple or maxima plugins is the key.
Here is your problem solved with various ways, roots() and Findroot().
solvewithunits.sm (23.4 KiB) downloaded 1447 time(s).
3 users liked this post
#3 Posted: 6/4/2023 2:18:41 AM
Hi. The attached have an al_nleqsol wrapper for a Mathcad block with units, that can accept SMath's integrals too.
Kerimov-Cvetkov-Velichko-1-7 - nSol.sm (17.97 KiB) downloaded 1471 time(s).
#6 Posted: 6/5/2023 2:24:02 AM
#7 Posted: 6/5/2023 11:08:24 AM
Hello Valery,
In some application(s), you can associate FindRoot with epsilon.
Solve Diophantine Chemical Balance epsilon.sm (106.1 KiB) downloaded 1499 time(s).
Valery Ochkov 6/5/2023 11:26:00 AM
#8 Posted: 6/5/2023 5:39:04 PM
#9 Posted: 6/26/2023 2:33:01 AM
Please help, why can't find root for this simple equation?
root.sm (20.2 KiB) downloaded 1412 time(s).
#10 Posted: 6/26/2023 5:54:06 AM
#11 Posted: 6/26/2023 8:45:01 AM
WrotePlease help,
why can't find root for this simple equation ?
roots solves wrt scalar function(s)
In this example, both functions are scalar wrt 'x'.
Try ... roots[(sin(x)-Gamma(x),x,1]
'x not defined' ... Gamma(x) is not scalar wrt 'x'
Few more numerical functions are not scalar
erf(x), erf(x,n) ... erfc(x), erfc(x,n) ...
#12 Posted: 6/26/2023 8:55:02 AM
WroteTry ... roots[(sin(x)-Gamma(x),x,1]
In that case and similar ones,
RootSecant algorithm will spits out 15 decimals, instantaneous.
Cheers ... Jean.
#13 Posted: 6/26/2023 10:06:59 AM
WroteWrotewhy can't find root for this simple equation?
Because there aren't unknows
Thanks Davide.
Now I put "N" as unknown in the Eq. But it can't be solved either.
root.sm (19.41 KiB) downloaded 1376 time(s).
#14 Posted: 6/26/2023 10:58:58 AM
You have to play a little with the precision, especially if there are units involved; in this case, seems that 10^-3 mm is a stable target (10^-2 works too, but in some case it returns the guess value, meaning that is "close enough" for the algorithm - you can see in the plot that 0kN to 200kN is in +0.02/-0.02mm range)
![2023-06-26 15_55_45-SMath Solver - [root_r1.sm].png](/en-US/files/Download/KcnuBb/2023-06-26-15_55_45-SMath-Solver---[root_r1.sm].png)
root_r1.sm (24.03 KiB) downloaded 1444 time(s).
netsonicyxf 6/26/2023 12:18:00 PM
1 Pages (14 items)
![2023-06-26 10_49_28-SMath Solver - [root.sm_].png](/en-US/files/Download/M4RRUF/2023-06-26-10_49_28-SMath-Solver---[root.sm_].png)
