1 страниц (7 вхождений)
LM Algorithm - LM Algorithm - Сообщения
For this particular example, Carlos algorithm spits out in < hart beat !
Thanks again Carlos, it will surely help revamp some/many of the GenfitMinimize.
Levenberg_Marquardt_Code_CBG Copy.sm (65,28 КиБ) скачан 1036 раз(а).
Andrey Ivashov 26.09.2018 18:15:00
Hello Jean,
The same example of the Levenberg Marquardt Algorithm, but obtaining
the Jacobian Matrix through finite differences
Levenberg_Marquardt_Code_CBG_Jean_JMFD.sm (77,37 КиБ) скачан 1005 раз(а).
WroteHello Jean,
Thanks, Carlos: works fine.
More doctoring for you !
The work sheet "Otherwise" is only slightly otherwise for convenience, works fine.
The "Jacobian Fails" is another model attempted, Jacobian complains ... Ah !
Same model Pharmacokinetics works fine Conjugate gradient Minimize.
True: some model function can only be fitted by hand
True: GenfitMinimze may be difficult to initialize but work fine for my huge
collection [about 80 projects in Smath].
Levenberg_Marquardt_Code_CBG Model Otherwise Jacobian FAILS.sm (35,77 КиБ) скачан 1030 раз(а).
Genfit Pharmacokinetics.sm (43,67 КиБ) скачан 982 раз(а).
Levenberg_Marquardt_Code_CBG Model Otherwise.sm (53,53 КиБ) скачан 1040 раз(а).
WroteMore doctoring for you !
Jacobian is rescued but does not finish solving
... God does not love Jacob anymore !
Levenberg_Marquardt_Code_CBG Model Otherwise Jacobian NOT calc.sm (39,62 КиБ) скачан 1001 раз(а).
Hello Jean
Here is the L-M file that works with your example.
Levenberg_Marquardt_JMFD_CBG.sm (53,29 КиБ) скачан 981 раз(а).
WroteHello Jean
Thanks Carlos for doctoring.
By some regrouping, timing dropped from 3.8 min down to 2.6 min.
Niece Smath document for classroom and publishing.
Genfit Pharmacokinetics L-M Copy.sm (60,57 КиБ) скачан 940 раз(а).
Hi Jean
Another example of the application of the Levenberg Marquardt algorithm,
this time with the Tesla function.
Levenberg_Marquard_Tesla_OK_CBG.sm (546,62 КиБ) скачан 1049 раз(а).
